Anyone have sources? - Defender Source
Old January 5th, 2015, 04:06 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Sort of an odd question but I know the community is large here.
The road spring seat(essentially very much identical on D1/d90/rrc/d2 vehicles, is basically a piece of pressed sheet metal I guess. There are two heights, early style(d1/rrc/d90) and d2 style; they're about a half inch different.
Does anyone have a way, or know someone that can make a deeper one? I'd like to drop my d2 about an inch or inch and a half without changing out the RTE springs that I really like.
Here's what it looks like -
Old January 5th, 2015, 04:09 PM
Won't it hit the axle of it is deeper?
Old January 5th, 2015, 04:20 PM
the rover shop
shayne young
Exactly what I was thinking..
Old January 5th, 2015, 04:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
If it were another 2-3", yes. But there is clearance to get another inch-inch and a half lower.
------ Follow up post added January 5th, 2015 04:31 PM ------
Here's the rear of a d2 for comparison
Old January 5th, 2015, 05:31 PM
What vehicle. Looking at my Defender, there is maybe half an inch clearance to the axle tube with the stock support. Just looking at a quick Google image search looks about the same on a Disco 2.
Old January 5th, 2015, 05:35 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
This is for my D2, I've already been playing around with the idea so I know the potential is there
Old January 5th, 2015, 05:51 PM
http://www.cs.unc.edu/~zhangh/LR/pics/watts2.JPG
I just don't understand.
Old January 5th, 2015, 05:58 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Man just cut a coil or two off those things!
I can make a set for you if you're married to this idea. Personally I'd swap out the springs...especially with the hookup (I assume) you get.
-Ash
Geared Restoration Co.
352-572-3236
Old January 5th, 2015, 06:06 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
Cutting the coil will increase the spring rate though.
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
Old January 5th, 2015, 06:08 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I don't cut coils!
And it looks like I'll have at minimum an inch or more to go down
------ Follow up post added January 5th, 2015 06:09 PM ------
I'm really more concerned about the front than the back. The back I can just take the spacer out.
Old January 5th, 2015, 06:11 PM
Your second picture shows a spring spacer..... Take it out....
Old January 5th, 2015, 06:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I addressed that at the end of my post
I do not understand the talk of cutting the springs. They have closed and ground ends...
Are you sure that front is normal stock? That support does not look like the deep one you posted above.
Old January 5th, 2015, 06:13 PM
After I posted.....
Old January 5th, 2015, 06:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
After I posted.....
Not according to EST
Either way, no the front is not stock. It can't be because the D2 has a stupid corkscrew design.
Old January 5th, 2015, 06:19 PM
Because before I hit the reply button, I refresh the page seven times...just in case someone edits their post....
Point being, is normal stock lower? Fark, those are some stiff looking springs.
Old January 5th, 2015, 06:23 PM
Also.... Basically you are asking if someone make a spring perch that won't work on a stock vehicle... In the time it took me to look at your post, we could have built a set of custom perches.
Old January 5th, 2015, 06:32 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It would work on a stock vehicle, I'm not sure what you mean by that?
Old January 5th, 2015, 06:38 PM
Ash's Avatar
Ash
Ash Heller
Sarcasm doesn't translate well on the internet.
-Ash
352-572-3236
Old January 5th, 2015, 06:49 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Kings brah!!!
I already have a safari gard with winch and the SG skid
Sources for LED Tail lights CDeWan Defender Technical Discussions 9 May 23rd, 2011 02:59 PM
POE liftgate struts-sources? PTSchram Defender Technical Discussions 6 February 6th, 2010 04:25 PM
Wheel Sizes and Sources Hoosier Defender Technical Discussions 14 January 19th, 2008 08:40 AM
parts sources and prices Gore Ranger Support & Suggestions 6 September 5th, 2007 01:00 PM
Diamond Plate Sources Kimos Defender Technical Discussions 19 December 2nd, 2004 07:55 PM
