Anyone have sources? - Page 2 - Defender Source
Old January 5th, 2015, 06:58 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Zack, the D2 rear spring seats are the "deep" type. The fronts are standard, same as D1/Defender. You could put a set of D2 rear spring seats on the front to drop it a bit... so long as theres clearance to fit the deeper seat.
Old January 5th, 2015, 07:26 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks Adam, I do know that; but the difference is only half an inch. I'd like to get a full inch or more
Old January 5th, 2015, 07:38 PM
transientmechanic
1972 SIII
You could get another ~1/4" by switching from the insulated D2 shock tower retainers to the old metal ring style.
Otherwise its a custom fab job... I could do it for you if you want to send me down a couple spring seats.
Old January 5th, 2015, 07:50 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I have inverted cones in the front, no insulated tower piece. Basically 1/16ths
Old January 5th, 2015, 08:00 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Like transientmechanic said - custom fab job if you any to get it done.
If you want to hack your axle and cut the mount and weld the spring seat directly to the axle housing? Might be alignment and differences in metal thicknesses issues.
Or take a 2nd spring seat weld it to the top of the first one and then cut out the parts you don't need. A plasma cutter should make short work of that.
Old January 5th, 2015, 08:04 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I may do that... Sans the plasma cutter
Old January 5th, 2015, 08:17 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I don't have anything with coil springs here to look at, but would you be making it hard to get to the bottom shock mount bolt if the spring seat was much lower than stock?
Old January 5th, 2015, 08:52 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Tony, I posted a photo of my shock mounts if you look on page one. D2s have 2 weld nuts so you don't need to reach into it
Old January 5th, 2015, 09:08 PM
the rover shop
shayne young
I've got a buddy who works at rovers north.. He could probably get you a decent price on the right set of springs...
Old January 5th, 2015, 10:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Unlike you, I don't have to haul $6k worth of random used rover parts at any given time!
Old January 5th, 2015, 10:24 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
bahahhaha
Old January 5th, 2015, 10:29 PM
transientmechanic
1972 SIII
Plasma cutter in my garage Zack... just saying! Will work for parts.
Old January 5th, 2015, 10:45 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Welder too???
Old January 5th, 2015, 11:23 PM
transientmechanic
1972 SIII
Si senor
Old January 5th, 2015, 11:25 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Well leave a few hours free on the weekend of the 24th...I'll be in the area!
Old January 5th, 2015, 11:29 PM
transientmechanic
1972 SIII
Sounds good... where are you going to be? If you need a place to stay or anything let me know.
Old January 5th, 2015, 11:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Boxford/Ipswich with the family, but I can drive to you
Sources for LED Tail lights CDeWan Defender Technical Discussions 9 May 23rd, 2011 02:59 PM
POE liftgate struts-sources? PTSchram Defender Technical Discussions 6 February 6th, 2010 04:25 PM
Wheel Sizes and Sources Hoosier Defender Technical Discussions 14 January 19th, 2008 08:40 AM
parts sources and prices Gore Ranger Support & Suggestions 6 September 5th, 2007 01:00 PM
Diamond Plate Sources Kimos Defender Technical Discussions 19 December 2nd, 2004 07:55 PM
