anyone got cruise control ? - Defender Source
Old April 22nd, 2010, 11:31 PM
Has anyone here fitted cruise control to a defender-specifically a 300 tdi ?
Old April 23rd, 2010, 07:27 AM
I'm on a mission. I do long road trips with the 130, 19hrs on the road kind of stuff, and cruise would be nice. Have a truck sitting around that has cruise just wondering if I can make it work on the defender....
Old April 23rd, 2010, 07:34 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have fit it to a 300tdi Range Rover and it was a pain in the arse even with the available factory parts to do it. It really doesn't work that well either with a mechanical diesel. IMO not worth the hassle for the result.
It's is much easier to accomplish with electronically controlled motors, most of which have factory supported cruise in one variant or another.
Matt Browne
Old April 23rd, 2010, 07:38 AM
damn. there you go popping my bubble....hope to get that steering column off to you early next week
Old April 23rd, 2010, 07:40 AM
Hand throttle?
Old April 23rd, 2010, 10:01 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Doug,
How about this system? Some requirements: 12 V vehicle electrics, mechanical throttle linkage, vacuum power source. I don't know much about a 300TDI, does it have a mechanical throttle linkage? I hope this helps.
http://www.waeco.com/EN/298_452.php
http://www.waeco.com/tmp/MS_50_EB_10S_01.PDF
A nice writeup:
http://forum.landrovernet.com/showth...cruise-control
MUDSUX
Old April 23rd, 2010, 01:12 PM
Originally Posted by cgalpin View Post
Hand throttle?
I have one in the series and one for a defender somewhere in the attic.
Old April 23rd, 2010, 01:36 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Got a brick?
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Ron ,
If you want to sell that hand throttle let me know.
Old April 23rd, 2010, 02:42 PM
johan's Avatar
johan
johan
2009 Range Rover
I have one in my Defender 300Tdi for almost 13 years, works great.
Bought it as an after market kit, make is John Gold. I thought it was made in US but I can only find a Dutch website about it.
http://www.goldautomotive.nl/
http://www.goldautomotive.nl/page---...nieken_82.aspx
It has an electric motor with a cable, very easy to connect to the lever of the injection pump.
Speed sensor, ECU and brake switch are quite easy to install.
I don't know if there are any US suppliers of this.
Johan
Old April 23rd, 2010, 03:04 PM
Morse ST single and a 3300 cable.
Old April 23rd, 2010, 08:40 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Didn't mean to let you down like that....
as Johan pointed out there are aftermarket systems. I had a customer truck with a similar set-up on a 110 a few years back and it worked OK, but frustratingly slow to react. It was installed by "one of those other shops" , and I never messed with it, but would think it could be better.
Matt Browne
Old April 24th, 2010, 12:59 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I have one in my '97 BUT I have an auto box and power brakes too. I used the factory speed senor (near the transfer case output) that drives the electronic speedometer for the speed sensor and tapped into the power brake vacuum line for the vacuum sensor. I'm using a unit made by Audiovox that I bought from PEP BOYS in 2002. Works great, never had a problem with it. Cost about $100.
Old May 6th, 2010, 10:50 PM
thats what I'm looking for !
Old May 7th, 2010, 07:52 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its pretty easy actually, and works well.
In the Tdi you'll just need to swap around your speedo cables and do a little mix and match so that you can supply the aftermarket cruise unit with a speed signal. We use the V8 EFI speedo cable (or you can use a VDO sensor) for the systems speed signal. The rest is nut and bolt stuff combined with some linkage bits and you are set. The new aftermarket systems are pretty slick actually and you program them sorta the way you do a VDO speedo.
Back 15 years ago or so the only aftermarket system they had only used a tachometer signal to drive the system and those sucked pretty bad (because it only read rpms, not road speed), but new ones can work just like a factory install (other than the fact you'll have to put the controls somewhere and that won't look very good (but that my my opinion).
Email:
Old May 7th, 2010, 08:08 AM
I was asking because I am going to Td5 gauges when I do the lhd conversion and will have an electronic speed sensor for that speedo and no cables. Sounds like I need to start shopping
Old May 7th, 2010, 08:18 AM
ECR's Avatar
ECR
That'll work just fine.
Just make sure the unit you buy is programmable. Some of the lower end ones only let you select a few examples of the input signal pulse count from the speedo sensor by flipping some dip switches and they may or may not have the pulse rate that the late model speedo sender puts out. If you find one that works like the VDO speedo (it grabs the pulse rate according to what you tell it to do) those work better.
Its kinda like power locks. Yes, it is another system to fail and if you don't know how to install and wire them they are scary, but if you do it right it will last for decades and be nice to have if you want a little convenience.
Email:
Old May 7th, 2010, 09:29 AM
Got a brand or model you suggest-preferably aesthetically pleasing as well ? Working towards driving the beat up old 130 to Moab in October-if the stars and planets align.
Old May 7th, 2010, 05:04 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You may already know about it, but the Wibbly wobbly speedo thread on LR4x4 will tell you all you need to know on how to install a Td5 dash onto an older wiring loom.
Old May 7th, 2010, 05:28 PM
Thanks Jamie,
Yes we printed that whole thread out and used it when we converted my brothers rhd 2.5 petrol 83 110 to: lhd, td5 dash, and Tdi. Lots of solder and heat shrink.
Doug
Noise control ttrover Defender Technical Discussions 37 November 29th, 2011 09:21 PM
99 RR Body Control Module chrisvonc Wanted 0 March 24th, 2006 11:16 AM
Wanted: wiper control cdnpaul Wanted 1 February 12th, 2006 05:45 PM
cruise control? kolvedic Defender Technical Discussions 10 October 18th, 2005 03:27 AM
