Anyone got a ECM I can borrow - Defender Source
Old May 6th, 2011, 08:32 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Anyone have an extra ECM for a 1997 90 I can borrow for a week or so while I send mine out to get repaired?
Old May 6th, 2011, 08:56 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have heard thet the D1 is the same if you get the same year.. maybe try will tillery.
Old May 6th, 2011, 12:49 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
If you are talking about the GEMS ECU they are normally coded to the vehicle/Alarm ECU so you'll probably need to get it programed to run your truck. You can't normally just switch them around between trucks unless whoever you get it from disables the Alarm Sync Feature 1st.
Old May 6th, 2011, 12:55 PM
dchapman
Daniel Chapman
1999 D1
I'm not sure that would matter on the D-90 since the D-90 does not have the "green box". The alarm ECU is what disables the truck, not the ECU. Even truck equipped with an alarm, the alarm can be by-passed and any ECU will start the truck.
The only exception to this, that I have found, is the P38 GEMs 4.6 ECU. I could not get the P38 ECU to work in a Disco no matter what I did (even with Autolodgic unlocking security mode). Not sure about Defenders, though.
Old May 6th, 2011, 01:02 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
97 D90s do have the 'green box'. The 10AS ECU is mounted behind the instrument panel bolted to the dash frame. Its only there to sync with the GEMS ECU at startup. Not sure if the wiring workarounds will work on a 90 or not though.
Name:	10AS Alarm ECU.jpg
Old May 6th, 2011, 01:20 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
97 NAS Defender GEMS ECUs are indeed coded to the vehicle.
Unless you code it with an AutoLogic (or other device) or use an unlocked ECU, it will not start the truck.
Email:
Old May 6th, 2011, 03:15 PM
Campbell's Avatar
Campbell
Rich Campbell
As always thanks for all the great advice. Looks like I will be renting a car.
Thanks again.
Rich
Old May 6th, 2011, 11:55 PM
He PMed me, but all I have are 14CUX ecus! I don't even have a spare car to loan him (unless he wants to swing by tomorrow and get one of the rovers back up and running).
Does Frank have autologic? There is a DI being parted out local
http://philadelphia.craigslist.org/pts/2361870090.html
Old May 7th, 2011, 05:31 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Ron.
It won't appear to work even if I found one since I have a 97. I think like everyone said it's coded to the truck. just sent it to Mike, he knows someone who repairs them. Even with the book to program..it won't work.
Thanks for even thinking of loaning me something, very nice of you. You've seen my mechanic skills, Do you think I could ever get one of your rovers running?
Let me know when you want to use my waxyol guns this summer.
R
wanted.. used Radiator to borrow for a few weeks TDI Guy Wanted 1 October 17th, 2008 01:37 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
numbering for the ecm pins? mattdh Defender Technical Discussions 2 April 26th, 2005 01:41 PM
ECM diagnostic output/interface on '94 jaherring Defender Technical Discussions 0 April 12th, 2005 09:48 PM
ECM Replacement?? Rob Defender Technical Discussions 2 November 24th, 2004 09:19 AM
