Anyone ever tried this? - Defender Source
Old May 8th, 2011, 12:30 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Need a second PAS pump on a 200tdi. I will make a bracket to hold it on top of left side of engine where the AC compressor usually sits. The question is ; Anyone have tried to put a second belt on the water pump pulley? Instead of having a third strap on the crank shaft pulley? A mean, since I use an kenlowe fan I could weld another pulley on the water pump and drive the auxiliary PAS pump from it?
Old May 8th, 2011, 12:32 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I'd run it off the crank, it's stronger and LR water pumps are known to have bearing failures...
