Anyone Ever fitted a RH drive instrument cluster to a LH dash? - Defender Source
Old September 19th, 2008, 06:24 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I was wondering if anyone ever attempted to fit a RH drive Instrument cluster to a LH drive dash. Sounds kooky I'm sure, but I'd like the idea of the speedometer on the far left, instead of far right, since my line of sight would be better focused on the other, smaller instruments. The Idea being to replace the gauges with VDO's, Speedometer, Tach, Oil Pressure, Coolant Temp (then put the fuel, a voltage and clock in the center dash).
Anyone ever try it? Anything physically in the way of doing such that anyoen is aware of? I've attached a photo of the reversed instrument cluster on a RH drive, unfortunately the best photo I could find in a quick search of the web was one that someone had mounted an electronic 'instrument' over the smaller instruments...
Would I need a new 'annunciator' panel as well? Anyone?
~Scott T.
'95 D-90 ST - AA Yellow
Old September 23rd, 2008, 10:49 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Bump...
Fidel, anyone?
~Scott T.
Old September 23rd, 2008, 02:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It will not fit. ITs just a little different shape
Legend in My Own Mind.
Old September 23rd, 2008, 03:22 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I don't like your answer, but thanks Randy. I was afraid that would be the case, it was a nice thought though..
~Scott T.
dash
SW Instrument Cluster Excellent Condition SafariHP The Vendors Loft 0 May 3rd, 2008 08:34 PM
Instrument Panel Cluster Replacement JMPDIV82 Defender Technical Discussions 11 October 28th, 2007 04:05 PM
97 d90 LH drive parts steved90 Defender Technical Discussions 4 January 16th, 2005 08:23 AM
defender instrument cluster needed ember Wanted 0 February 26th, 2004 02:01 AM
