Anyone ever considered a turbo pre-filter for oil feed? - Defender Source
Old January 29th, 2015, 04:50 PM
This seems like a really good idea considering I've become the poster child for turbo issues. Clean oil and air is paramount, and this seems to be the way to go. particular for off highway vehicles.
http://store.forcedperformance.net/P...4ANFilter.html
Mark Kellgren
KM4BOR
Old January 29th, 2015, 05:04 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Seems like a simple insurance policy, just make sure you inspect the element often. Is oil contamination what killed your last turbo?
-Ash
Geared Restoration Co.
352-572-3236
transientmechanic's Avatar
transientmechanic
1972 SIII
Seems like it would just be more likely to plug and starve the bearings?
What oil filter do you run on the engine? Please dont say Fram
Old January 29th, 2015, 05:16 PM
Not sure I understand why they do this. The main filter will filter out anything anywhere near large enough to get stuck or damage a bearing.
Some people run a bypass filter system. These are fine enough to pull soot out and are great for extending oil change intervals.
Old January 29th, 2015, 05:55 PM
Adding a remote filter might work and use the same filter. Td5s have two filters. Centrifugal and regular.
Old January 29th, 2015, 06:15 PM
-Ash
Appears so.
------ Follow up post added January 29th, 2015 06:17 PM ------
Not anymore! I had no idea fram was shiite. Thats what my mechanic said today. "Stop using fram!"
What are the premium turbo friendly filters?
Mark Kellgren
KM4BOR
Old January 29th, 2015, 06:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I agree with Adam... any filter would restrict flow and if it ever clogged, the turbo would fail quickly.
The engine already has an oil filter, so anything in-line with the turbo feed would be redundant.
RDavisinVA
Old January 30th, 2015, 09:50 AM
transientmechanic
1972 SIII
You can read about it for hours on bobistheoilguy
General consensus seems to be Purolator PureOne is "one of the best". The part number that fits the Tdi is PL30001. About $7
------ Follow up post added January 30th, 2015 09:52 AM ------
Also what oil are you using in the engine? It's unusual that you have killed multiple turbos... there must be some consistent factor that is causing the failure.
Old January 30th, 2015, 10:07 AM
Thanks. Where does LR genuine rank against the Top filters?
After break in, i switched to Mobile One Turbo Diesel for awhile then switched to Rotella T6. The first 2 turbo's died becuase of coolant contamination in the oil, due to a cracked head that i failed to recognize. so that was on me. but this last one needed the thrust and journal bearings replaced. that was a bit of a mystery. I'm going to take them to another turboshop to get a 2nd opinion since I didn't get anything conclusive from the current shop.
Mark Kellgren
KM4BOR
Old January 30th, 2015, 10:09 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Chevron Delo 400LE. It's cheap at Costco.
I'd use Schaefer but it's so darn expensive. And hard to find.
Black Rhino Lives Matter
Old January 30th, 2015, 10:41 AM
This is sort of anathema to the post, but boost leaks will also kill a turbo. I'm sure that filtering helps but a lot of oem turbos on passenger cars run without them.
Old January 30th, 2015, 10:48 AM
that was probably a contributing factor as well then. I had been battling a bad fitting seal and then a tear in my pressure side silicone hose. That is all resolved now.
Mark Kellgren
KM4BOR
Old January 30th, 2015, 10:56 AM
transientmechanic
1972 SIII
Either of those oils should be OK, my personal choice is Valvoline Premium Blue. It seems to have the best anti wear additive mixture.
Good info about the boost leaks- that will definitely cause the turbo to work a lot harder!
How are your driving habits with the engine - do you give the turbo adequate time to cool down before engine shutoff if its been driven hard? (For example, if you live right off an interstate off ramp or at the top of a mountain, that turbo is going to be HOT when you pull into the driveway).
Old January 30th, 2015, 10:58 AM
No issues with driving habits. It gets a cooldown after runs, especially on interestates. and engine always gets a minute or two idling before going anywhere.
Mark Kellgren
KM4BOR
Old January 30th, 2015, 01:00 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Just ordered 2x of these, good recommendation, looks like you have spent some time looking into this
Old January 30th, 2015, 01:06 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Are you going to use them as bookends or do you have a truck to put them on yet?
Totally kidding man! You do need to get your truck though, jus sayin
Old January 30th, 2015, 01:29 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I am going to make a coconut bra out of them and use old seatbelts to make a hula skirt.
Video to follow
Old January 30th, 2015, 01:44 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Subscribed!
-Jeff
Old January 30th, 2015, 02:28 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
These guys do good work.
https://www.tristateturbo.com
Old January 30th, 2015, 02:37 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I am going to run a pressure switch at the banjo fitting for mine just so I know for sure its getting oil. My turbo was eating itself last week and not sure if it had play before the rebuild (felt fine when I put it in) or if it wasn't getting enough oil. I cracked the line and oil was flowing to it. but for piece of mind I am fitting a switch so I know its getting oil.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
LT230 PTO cover & oil feed plate Landy_Andy Wanted 0 October 13th, 2014 09:36 PM
Turbo oil feed banjo bolt size? o2batsea Defender Technical Discussions 1 July 22nd, 2013 04:55 PM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
RHD (less than 25yrs old) can now be considered under petition Uncle Douglas Misc. Chit-Chat 12 December 15th, 2010 07:11 PM
Tdi pre-filter draining tap JFD Defender Technical Discussions 7 July 21st, 2010 01:34 PM
