Anyone drill and tap out a broken stud in a NAS door top? - Defender Source
Old September 21st, 2010, 02:57 PM
I broke off the last 3/8th of an inch of the door stud in the door top. Don't ask why I was taking out the studs. Do I have to disassemble the door top? I cant see how I would get to it from below as it is way in up in there and I can't fit a tap. Any tips would be appreciated.
Ron (the man with one ROW limestone doortop on his NAS D90)
Old September 21st, 2010, 03:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Planning to send your doors shortly if that helps
Old September 21st, 2010, 04:19 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Is there any for the stud left sticking out?
I would be careful drilling in that aluminum.
Old September 21st, 2010, 07:38 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
drill it out with reverse drill bits.
- Charles Eames
Old September 21st, 2010, 08:47 PM
No, the tip of the stud broke off in the door top.
Thanks Barry.
Those will be great, but I still want to fix this one.
Old September 21st, 2010, 09:28 PM
ron
just drill it out. If it is broken down at the bottom of the hole then you can use the hole to center the drill bit. if you bugger the threads, you can use a helicoil to repair them. maybe.
left hand drill bits can sometimes help get a stuck screw out too
Old September 21st, 2010, 11:59 PM
I can drill it out but I can't see it because it is 2in in the hole.
If I take off the channel and windows, I can maybe drill through the top.
Thoughts?
Old September 22nd, 2010, 12:31 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I drilled out one of mine in my old doors, but it was broken off farther up than yours. It was a PITA. Eventually I replaced the doors as they were getting rusty on the bottoms anyway :-S
Old September 22nd, 2010, 12:45 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
I'd make a drill guide bushing - which you can use because it sounds like it broke off up in the hole a ways (which is really weird) - Easiest would be to drill a hole in the center of a bolt the same thread as the stud (you have access to a lathe? Makes getting that hole centered easier). Drilling a steel bolt in aluminum, the drill wants to wander off into the soft aluminum and then everything is buggered.
Once you have a good center hole drilled, you can increase size more easily without as much fear of wandering off. As said, a reverse bit is nice as once you get the hole to a good size, the bolt remains will loosen and spin out with the reverse rotation.
few things I hate doing more.
Old April 20th, 2013, 06:14 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Broke the stud taking the door top off. Drilled into the broken stud and was able to get an easy out to bite. I've been spraying it with liquid wrench for a few days now and it won't budge to back the broken stud out.
At the point of drilling out the rest of the stud but need to know what I should use to tap it for a new stainless steel stud.
I need the thread size to tap it and drill bit size to drill it out with.
Old April 22nd, 2013, 11:09 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Ran into this myself for my middle door tops I have. I didnt put any spray lube on it and it snapped about the surface. Figured I would just take it to a shop and have them drill the broken stud out and fill in with aluminum then drill and tap it.
Old May 4th, 2013, 08:19 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Drilled it out, and tapped it. All back together but now they both leak. Replaced the rubber seal between the window and the door top. The previous rubber piece had a notch cut out and I am wondering if I need to do that to these? Possibly to allow the water to drain out instead of running down the bolts into the door.
Old May 4th, 2013, 08:36 AM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
That's exactly what the original notch was for, to allow water to drain out to the outside of the door, otherwise it has nowhere to go but down the bolts into the inside of the lower door, helping the frame to rust out nicely.
Old May 4th, 2013, 11:59 AM
wantone
Rick Thompson
94 ST #1222
I have ron. I drilled it out from the top after removing the glass. I made sure i center punched it real good & started with a small bit & worked my way up in size up to where i almost got into the threads to "weaken" them. Then i did the same from the bottom but only went to a 1/4" bit. Then used an easy out to get it. PITA. After i put the studs back in i put O rings over them after the seal & that has kept water out of the stud holes in the doors
door, nas
Hole Tapping kennybahr Defender Technical Discussions 2 July 22nd, 2008 11:01 PM
