Anyone done their own head gasket? - Defender Source
Old October 5th, 2004, 09:03 AM
vesparover's Avatar
vesparover
brian bertolini
Exclamation Anyone done their own head gasket?
Hey everybody, I blew my headgasket a while ago and it's time to fix it. I'm gonna do the composite gasket, but need to know what else I should do while I'm in there. If anyone has any tips or tricks that I should be aware of, it would be greatly appreciated. Also, I'm gonna upgrade to a 4.6 down the road, should I use these heads or buy a longblock 4.6?
thanks
Brian Bertolini
Old October 5th, 2004, 07:42 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Send the heads out and get them inspected, cleaned, and a valve job done. Might also want to get the fuel rail and intake hot tanked while they're off. Obviously inspect everything internal while you're in there. It's not a hard job, just a lot to pull off, but no more than an afternoon's work.
Old October 6th, 2004, 03:03 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
An afternoons work and the dealer charges $2,000 to do it
Old October 6th, 2004, 03:48 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I've just come to find out that my head gaskets are leaking also, although they've just begun to leak (not a massive leak yet). The question I have: how long can I go before doing the work? I've had so many other expenses on this truck lately that I'm a little tight on expendable cash at the moment.
West Coast Rover charges $1250 which includes the valve job, BTW. I thought that was a fair price. When I get mine done I'd like to get the valve covers and intake plenum powdercoated while they are off. The corroded aluminum look doesn't work for me.
Old October 7th, 2004, 06:56 PM
mlw911
Michael Walter
1995 D90 ST
Jason:
A good wire brush will bring back the intake plenum and valve covers to almost new condition with a little bit of elbow grease.
Old October 7th, 2004, 07:38 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Yeah, I have a wire wheel and an air compressor and not afraid to use it! But I thought it would look great powdercoated (roughly) the same color as the body. You'd be surprised how inexpensive powdercoating can be if you find a shop sending off an order anyway (I piggyback on a local shop's orders) and it's extremely durable.
Old October 7th, 2004, 10:06 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Damn, Jason. That truck has turned into quite a project for you!
Old October 7th, 2004, 10:35 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Going to be doing mine next summer, along with the timing chain. Just a preventative sorta thing, fix it before it goes.
I was thinking using some Gliptone on the inside of things, supposedly that stuff works great to keep the oil moving around. Anybody try that yet?
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 8th, 2004, 02:56 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
I think that depends on exactly what's leaking, and where. External oil leaks maybe you can let go, but it's not going to get better by itself. If it's coolant leaking into the oil passeges, it may already be too late.
Old October 8th, 2004, 03:10 AM
12-15 years for an oil leak.
5-10 years for the small coolant leak at the back they all have
Coolant leak, other than the small one at the back not too long it needs to be addressed now.
Let me tell you a secret. 80% of rover V8 head gaskets are leaking right now. My D90 is amazingly in the 20% as was one of my discos (just had them done), but the other disco was a chronic leaker and the lwb is a seeper.
Ron
Old October 8th, 2004, 10:49 PM
mlw911
Michael Walter
1995 D90 ST
Rob:
Can you clarify on the coolant leak. Mine is leaking on the back of the block and just recently I noticed when I leave the car idling it starts moving towards the red zone. Is it time? Also my engine only has 60k on the clock and runs great. Do the heads really need to be done at this point? For the sake of the saving $$$ I would rather just replace the gasket myself and have the heads done like in another 50k.
Old October 8th, 2004, 11:12 PM
humm, is the coolant topped off? the little leak at the back does not make it overheat.
Old October 9th, 2004, 02:58 AM
Hans's Avatar
Hans
Hans Haase
Well, considering my emissions problems and how little external emissions parts there are, I am thinking that I am probably needing to do my head gaskets sooner than expected. Getting a slight popping in the exhaust and a touch of the overheat. Since I have to do a major teardown anyways, should I just go for the gusto and do the cam and lifters too? I'd hate to have to pull the intake manifold AGAIN later on.
Grrr, I was hoping this could all wait until I had the truck paid off and I'd just drop a 4.6 in it.
-Hans
My oil line fix
Old October 9th, 2004, 03:09 PM
Hans,
have the 02s checked.
Old October 9th, 2004, 03:12 PM
Hans's Avatar
Hans
Hans Haase
Originally Posted by evilfij
Hans,
I'll grab the multimeter tomorrow and test them, but they look almost brand new. Hmmmm
-Hans
My oil line fix
Old October 9th, 2004, 03:33 PM
When they go bad they switch slowly.
BTW what is the HC limit where you live?
Is it a 95 or a 97? If it is a 97 there are a fewer things to fix. 95 a tune might work if it is close.
Ron
Old October 9th, 2004, 10:34 PM
Hans's Avatar
Hans
Hans Haase
I have an early '94. Limits I think are around 250ppm and mine was spouting over 400
-Hans
My oil line fix
gas
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 11:24 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
