anybody used the CANEMS kit? - Defender Source
Old April 19th, 2011, 11:42 PM
cdb
Clark Bowen
http://www.lloydspecialistdevelopmen...rover-v81.html
Looks like an offshoot of Megasquirt, but comes complete and ready to install.
Big issue would be reliability since you wouldn't have a backup. The 14CUX won't work with the distributor-less ignition.
2011 RR HSE -
2001 GMC 2500 4wd
Old April 20th, 2011, 04:21 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Yow! That's over $1700. You can buy plug-and-play MS for the Rover V8 for $700 less.
http://www.extraefi.co.uk/RV8_Kits.html#wasted
For about the same price you can get a plug-and-play MS 14CUX compatible
http://www.v8developments.co.uk/
Tony
1984 110 "Smokey" (sold)
Old April 20th, 2011, 11:40 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I believe that V8development suppose to be coming out with a straight swap for the 14cux ecu to a megasquirt so you dont have to replace the harness or anything as well.
Old April 20th, 2011, 09:36 PM
cdb
Clark Bowen
Tony.....
Since I already added a MSD 6a CDI, Blaster coil and the Boost Timing Master I seem to have a rudimentary and adjustable ignition control, so I could just get the MS Plug and Play Fuel Only replacement for the 14 CUX instead of entering into a completely new world of re-wiring for distributor-less ignition without any backup.
I read CANEMS installation and knew I was way beyond what I wanted to learn and do.
If the MS unit bellies-up, then I could plug in the 14 CUX, switch a couple of connections and be back on the road. Right?
I like the lower price, less hassle and having a backup, but how much performance will I lose by not having the system directly control the ignition? Any idea? I intend to have it dyno tuned.
William...
Yes they do and here it is: http://www.v8developments.co.uk/ under products and injection
2011 RR HSE -
2001 GMC 2500 4wd
Old April 21st, 2011, 10:58 PM
cdb
Clark Bowen
Sent V8Ddevelopments an email and Shaun responded right back.
Very helpful, detailed answers to all my questions and good suggestions.
Decided to go with the Plug and Play fuel only replacement for the 14CUX but with 2 AFR inputs and wired so that I could add a crank-fired distributorless ignition later. Takes about 10-20 minutes to install and I can use the 14CUX for a backup. You also delete the restrictive MAF with this setup.
Shaun recommended that I just use the software to program the ECU and that a dyno wasn't really necessary.
If anyone is interested I'll post again after I install and tune it.
2011 RR HSE -
2001 GMC 2500 4wd
Old April 22nd, 2011, 03:52 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Good news, sounds like just the solution you were seeking.
Tony
Old April 22nd, 2011, 01:13 PM
cdb
Clark Bowen
Tony....
Really appreciate your ongoing advice.
This is an entirely new area for me - electronics, supercharging, programming - and you've been very helpful.
2011 RR HSE -
2001 GMC 2500 4wd
body, kit
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Kenlowe Twin 13" HD Fan Kit Barnett Childress For Sale - Parts 1 September 7th, 2005 04:01 PM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
