Anybody ever redone the steering joints? - Defender Source
Old January 18th, 2006, 10:11 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
My steering is getting a bit too loose for comfort lately, time to order me some tie-rod ends and rebuild the pitman arm joint. Anybody ever done this area? Any pitfalls to look out for, areas to be concerned about and such? Hints, tips, tricks or other advice welcome.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 18th, 2006, 11:14 PM
Yeah, I've done it, its super-easy except for the fact that all the old joints can be mega-difficult to remove. I had the steering box out of the truck when I did mine and everything took much persuading. It goes back together really easy, and naturally you go get an alignment when you are done.
Note center of ball joint to center of ball joint dimension for the steering arm, and the measurement for the track rod. That way when you put it back together the alignment wont be way off and you can drive to the shop without a religious experience.
I just used a drop arm ball joint kid and new ball joints from RDS.
Old January 19th, 2006, 12:43 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My steering is gettin pretty nasty, and I actually just signed on to see about asking the same question... That makes it easy.
body
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Loose steering kellymoe Defender Technical Discussions 2 October 15th, 2004 08:42 PM
