any tips before I Gunk the engine/trans/diffs? - Defender Source
Old March 16th, 2009, 10:24 PM
johnpiero
John Brancato
none
Hey all! Gonna do a little spring cleaning on the engine bay. Any advice? Should I wrap anything up: ie: dist cap?
Old March 17th, 2009, 12:45 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Have a ride home or to work lined up LOL
Have a rag on hand and just clean out the cap and rotor after. If you can blow air in the spark plug holes around the plugs it is good as well. I try to drive the vehicle 10 miles afterwards to use the engine heat to dry up things before parking it. Prevents no starts the next day.
legend in my own mind
Old March 17th, 2009, 12:59 AM
Do it while it is running.
Old March 17th, 2009, 07:59 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
When I have pressure washed , both at the car wash and at home, I have problems starting. The two culprits have been moisture (water) getting into the distibutor and the two connectors for the ignition amplifier. Once these were dried out, starts and runs fine.
Old March 17th, 2009, 09:26 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Don't use pressure, use degreaser. Pressure wash force
the water where it is not supposed to go. Gunk, rag and
garden hose will work fine.
- Charles Eames
diffs, engine, fs
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 05:14 PM
Springs & Shocks Install Tips javelinadave Defender Technical Discussions 29 May 12th, 2007 10:11 PM
Preventative Maintenance? Tricks? Tips? Upgrades? pcscharfe Defender Technical Discussions 7 February 20th, 2006 12:53 AM
New Defender owner needs tips... tboyle27 Defender Technical Discussions 12 December 14th, 2005 01:18 PM
Engine Block Heater for Defender 110 - tips? COSteve Defender Technical Discussions 10 December 6th, 2005 01:12 PM
