Any suggestions - Defender Source
Old May 21st, 2005, 08:39 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Any suggestions
Land Rover: 1995 SW w/ 75,000 miles/Fuel Filter changed 1500 miles ago.
Problem: Rover ran fine last week. The car starting sputtering around 70 miles an hour. I did not think I would make it home. I got off the highway and it ran great around town. Now it sputters at any speed. It idles fine. Starts fine.
I am thinking it is the speed sensor? I did a search on the forum but the symptons did not match mine. Could it be the fuel injection? Any help would be appreciated. This forum always saves my ass.
Old May 21st, 2005, 08:59 AM
Hmmm, I would check the connection to all the spark plug wires at the cap and the plugs. Mine started doing the same thing when I bought it a few years back and there was corrosion on a couple of the connections. But you say it is fine when idlesing, mine had a ruff idle, Any engine codes? I would also say to check fuel pressure but I don't think there is an easy way to do this on a 95.
Sleep and Store suggestions michael15 Defender Technical Discussions 17 May 1st, 2006 03:38 PM
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 06:55 PM
Roof Rack Suggestions skibigwest Defender Technical Discussions 1 February 21st, 2006 01:55 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 08:59 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 10th, 2004 11:12 PM
