Any reason not to double clutch? - Defender Source
Old September 13th, 2004, 07:12 PM
mspell
Michael Spellman
Started double clutching this weekend, it's definitely easier on the 1-2 shift, is there any reason not to do this?
Old September 13th, 2004, 07:30 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Originally Posted by mspell
"Started double clutching this weekend...is there any reason not to do this?"
Only one:
Makes your passengers think you're having a seisure.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old September 13th, 2004, 09:03 PM
I do it some when its really cold and the fluid needs to warm up. What transmission fluid are you running? I dont think it is nesccesary.
Old September 14th, 2004, 08:15 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
It may get necessary when the synchros get worn.
Old September 14th, 2004, 09:09 AM
mspell
Michael Spellman
I'm not having any synchro issues, the gearbox has 10k miles on it, I was thinking more as a preventative measure.
Old September 14th, 2004, 10:25 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I used to practice shifting without the clutch in my 109. Match road speed and engine RPM and it would shift right in withiut the clutch. I also used to practice double clutching with the 109, the fire engine I drive at work requires double clutching in all gears.
Old September 14th, 2004, 12:10 PM
a good tranny fluid is a good precaution, there is alot more going in your gearbox that would benefit more from a high quality fluid than can be prevented by double clutching.
Old September 14th, 2004, 01:12 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Mike Green of West Coast British recommends 1 qt Castrol Syntec 5/50 and the rest D4 Redline. I have that mix and it's noticeable better. And my 3rd gear syncro has been gone for 40K miles...
Old September 14th, 2004, 06:31 PM
draaronr's Avatar
draaronr
Here
LR3
Are we talking R380s here or will that work in a lt85, manual says to use 15w40 motor oil for it.
Old September 14th, 2004, 09:44 PM
I got the redline MTF, I cant stress how much of an improvement that made, I guess its prolly obvious when you look at my posts in regards to the matter....
Old September 14th, 2004, 11:26 PM
Doug's Avatar
Doug
Doug Walker
I'm using MTF in the T-case, D4 and Syntec in my L77 which calls for ATF in the manual.
Old September 15th, 2004, 12:15 AM
How's it feel, I thought about the MTF in my LT but I am not sure, I am using the Mobil 1 syn which it seems to like........ I would like to try something else for shits and giggles.........
Old September 15th, 2004, 12:45 AM
MTL or MTF?
MTL is right MTF is what?
Old September 15th, 2004, 12:58 AM
MTL sorry I might be under the influence....
http://www.redlineoil.com/products_g...sp?subcatID=18 I have almost 3 quarts of that in my R-380.......
Old September 15th, 2004, 01:03 AM
Milo's Avatar
Milo
chris glynn
95 yellow D90
check this out, might help:
http://www.cruzers.com/~twakeman/LR/FAQ_clutch.htm
COME ON, DO IT, DO IT!
"Maury Finkle, founder of Finkle Fixtures, Biggest Lighting Fixture Company in the Southland."
Old September 15th, 2004, 02:10 AM
Doug's Avatar
Doug
Doug Walker
Well now, where's the part about heel and toe? After all, one needs a foot for the brakes, since using the e-brake is a no no in the Land of Rover...
Old September 16th, 2004, 01:05 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Just an FYI, but in my opinion, you really shouldn't be using MTL in the Transfer Case. The Transfer Case calls for a GL-5 rated gear oil (75W90), also known as EP or Extreme pressure (I say this because I think this is how it is actually refered to in the owners manual) gear oils. MTL is a GL-4 rated oil, designed specifically for transmissions, that are shifted regularly and at speed. GL-5 (EP) gear oils are bad for the syncronizers because one of their additives (the name escapes me at the moment) reacts poorly with the brass in the snycronizer rings.
Also as an FYI, most of you probably know, but Land Rover put out a service Bulletin in late '97 changing the R-380 lubricant recomendation from ATF to a product called MTF-94. It is produced by Caltex of Australia, and its specifications are nearly identical to RedLine's MTL. Here is a link...
http://www.caltex.com.au/products_oil_detail.asp?id=107
If anyone cares, I actually run RedLine's 75W140 GL-5 Gear oils in both Differentials, the transfer case, and the Swivel Balls, and MTL in the R-380 Gearboxs of both my Defender and my Discovery. I've been very happy with the combination.
~Scott T.
'95 D-90 ST - AA Yellow
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
