Any problems in using "Diesel" 15W40 oil in gasoline engine? - Defender Source
Old March 10th, 2011, 03:26 PM
Knife90
john sabra
'94 Defender 90
I went to buy oil today to do a change, and the only 15W40 oil they had was "Motorcraft Super Duty Diesel 15W40". The sales guy seemed very confident in assuring me that the "diesel" name on it is purely an advertising approach, as 15W40 oil is 15W40 oil. Seems to make sense to me, as whats happening inside the combustion chamber shouldnt have any effect on the oil lubricating the outside moving parts. (this is my non-mechanic analysis here). unless operating temp or something else would be affected? you guys think its ok to use this?
Old March 10th, 2011, 03:33 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://www.ehow.com/about_6386085_di...otor-oil_.html
Old March 10th, 2011, 03:47 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It's actually a very good oil for these older design rover v8's.
Old March 10th, 2011, 04:35 PM
Yes, for old style engines, with flat tappets, diesel oils are a good choice. There are some downsides for some modern engines.
Old March 10th, 2011, 04:38 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I use nothing but Rotella T 15w40
Old March 10th, 2011, 04:40 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I ran delo 15w40 in my rangie for 80k miles. Passed smog in california with no problems everytime. I didn't use it but britishpacific recommends redline engine oil break-in additive to increase the zddp.
Red Line Engine Oil Break-In Additive
for 1987-2004 3.5, 3.9, 4.2, 4.0, and 4.6 pushrod Rover V8 engines, and all Series 2.25 engines.
Flat tappet engines require a zinc blend for friction reduction in their oil. This compound, known as ZDDP, has been an important part of engine oils for decades. But California requires that all emission parts be warranted for 100,000 miles, including catalytic converters. Sometimes that's tough for manufacturers to meet, especially if the engine using oil. The zinc can clog converters over high mileages. So, the manufacturers have persuaded the oil companies to eliminate ZDDP, which is being phased out nationwide.
Modern engines are designed for low internal friction so the zinc really isn't required anymore. But older engines still need it. The wear is first seen on cams and tappets, where friction and pressure is highest. We've seen freshly rebuilt engines destroy cams and lifters within a few thousand miles due to this oil formula change.
To protect your engine, add one bottle of Break-In Additive to restore zinc levels to your conventional oil for the first few changes. The product reduces friction, improving efficiency and mileage. It's also fortified with detergents, dispersants, and antioxidants to keep the engine clean. It does not alter the viscosity of the oil, and it can be used with both organic and synthetic oils.
Daniel
Old March 10th, 2011, 06:39 PM
Knife90
john sabra
'94 Defender 90
thanks guys, appreciate the advice.
Dan, i'll get that additive, seems to make sense.
Old March 10th, 2011, 09:30 PM
i have actually used Amsoil Desiel 10/20 in my race cars for years (all build prior to 1992)
after the change to less ZDDP in morot oils (mobile one for instance) this was the natural choice
in our trucks match up the weight to what you would normally use and it will a) be fine b) be better for the older engines.
all IMHO of course YMMV
95' D90 - daily driver..
diesel, engine, gas, problems
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
