Any one have the Rovers north LED tail lights? Pictures please - Defender Source
Old May 1st, 2014, 03:26 PM
was looking at both options
RN & Mud UK
95' D90 - daily driver..
Old May 1st, 2014, 03:35 PM
There are a bunch of pics of them in the main LED threads on here if you search around.
Old May 2nd, 2014, 07:01 AM
Lemonhead
TB
1997 D90 SW
Old May 2nd, 2014, 08:45 AM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
RN are Wipac and MudUK are Trucklites?
Old May 2nd, 2014, 09:11 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Indeed
Old May 3rd, 2014, 04:44 PM
thanks lemon head.
on the fence wrt to the RN ones - i like the truck lites but the RN ones look pretty good too and are about 1/2 the cost.
Old May 3rd, 2014, 11:11 PM
Who's are the "best". I like the LEDs once I install the Mantec tire carrier and new seat foam I'll b satisfied.
Old May 4th, 2014, 12:05 AM
Depends on which design you like the most. The trucklites are the closest to stock (design) but also the most expensive.
Old May 4th, 2014, 08:34 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I biught my rear led's and plinths from Justin at lucky8 and they were able to get me the same RN ones with relay for less. Easy to install
Old May 4th, 2014, 11:52 AM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I installed the Wipac lights from Lucky 8. The fit and look very original. There is not much room in the plinth, so the plugs are on exposed to the tire spray. I wanted to use an o-ring sealed multi plug, and that took a bit of time to sort the wiring. Spend some time thinking how you want to wire them. The way I did it is a one way conversion due to drilling. Also, you will need to install the load balancers or use an adjustable flasher. I used the adjustable one which works well, but the trailer indicator also flashes with the signals. Good luck!
Angus
Angus
Old May 4th, 2014, 12:31 PM
rovertrader's Avatar
rovertrader
Dale
Robert, my 110 has them, so take a look/see while it is up your way...
Old May 5th, 2014, 01:32 PM
thanks Dale - i'll go check it out soon hopefully
Old May 5th, 2014, 01:43 PM
Closest to NAS stock?
There are NAS style LEDs and there are ROW style LEDs. I believe Wipac and RDX make versions of both and the NAS ones cost more. Is Trucklite only the NAS style? Someone need to get ahold of each and do a comparison. A great project for a magazine.....
Old May 5th, 2014, 01:48 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
http://www.eastcoastrover.com/LED.html
Old May 5th, 2014, 01:56 PM
The Trucklite / Rubbolite LED ones for NAS stock that we've referenced a bunch of times are closest to the stock appearance for a NAS truck. They are the ones that ECR also uses for their builds, and we have had a few lengthy threads and group buys for these lights put together on this forum. The Wipac lights that RoversNorth and Lucky8 and the like sell to replace the NAS stock lights show individual ports for each diode and do not look as close to the NAS stock appearance as the Trucklite/Rubbolite ones that Mud UK is selling.
I do not know anything about the ROW lights.
Old May 5th, 2014, 02:02 PM
I just thought it best to mention that there are two different styles as people tend not to say which kind they are looking for. Rovers North sells both.
Old May 8th, 2014, 06:25 PM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
FYI. MUD sell the LE Perei lamps that are the OE spec' lamps LR uses on its special edition models. This lamp is now the closest to the look of the original NAS lamps since the Trucklite lamps are now no longer available in the ECR style.
Trucklite has changed the design of its lamp so that it now looks exactly like the Wipac/RDX/RN lamp with the more pronounced LED units. The Trucklite part numbers have remained the same despite the change of lamp style.
Old May 8th, 2014, 06:44 PM
Originally Posted by Kev Baldwin View Post
FYI. MUD sell the LE Perei lamps that are the OE spec' lamps LR uses on its special edition models. This lamp is now the closest to the look of the original NAS lamps since the Trucklite lamps are now no longer available in the ECR style. Trucklite has changed the design of its lamp so that it now looks exactly like the Wipac/RDX/RN lamp with the more pronounced LED units. The Trucklite part numbers have remained the same despite the change of lamp style.
Wow, really? Did you order trucklites and those showed up, or how'd you find this out?
Old May 8th, 2014, 06:49 PM
The Perei is available in normal and LED versions.
Old May 9th, 2014, 11:29 AM
Kev Baldwin
Kevin Baldwin
That's exactly how I found out!
To add to the confusion the Trucklite website was showing a mixture of both old and new style lamps. Following discussions with Trucklite in the UK they've assured me they have no old stock remaining.
The ECR Trucklite rear LED lamps are officially unobtanium!
ht, lights, tail lights
WTB: LED Tail/Marker Lights 1997 NAS D90 1911D90 Wanted 1 May 25th, 2012 06:34 PM
LED tail lights question BadMonkey Defender Technical Discussions 3 November 10th, 2011 03:59 PM
Sources for LED Tail lights CDeWan Defender Technical Discussions 9 May 23rd, 2011 02:59 PM
Any one have an extra one roverup Wanted 3 July 9th, 2009 01:46 PM
Rovers North Tail Lamp Guard Install Arnzo Defender Technical Discussions 13 September 6th, 2008 07:17 AM
