Any issues with putting sound insulation underneath rubber mats? - Defender Source
Old February 25th, 2005, 11:44 AM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Hi All,
I'm replacing the carpetting that came with my 95SW with the rubber mat that came on the Soft Top models.
The PO really did a number on it, and cut it into shreds, etc.
I'm planning to put some sound/heat insulation under the rubber matt, to cut down on noise.
Is there any reason why I shouldnt do this?
I do realize if it gets wet underneath, it wont dry out..but is this really an issue?
-arbi
Old February 25th, 2005, 12:06 PM
jabber
m j
110
There shouldn't be any problems... I've actually done that on my ST. I would highly recommend you prep the areas WELL!!! Make sure they're clean and free from rust. That way when you do put the material down it sticks well, and should keep water from sitting.
I actually used IceShield from Home Depot/Menards. Thus far I'm very pleased with it.... AND it was cheap.
Old February 25th, 2005, 12:27 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
I just did the same thing with my SW about two months ago. You probably already know this, but I don't think the sound protection will absorb or retain water after application if it is asphault based like Dynamat Xtreme.
I was having a problem with the padding under the carpet holding water and rusting all the bolts in the floorboards. I feel alot better now that the carpet is gone and I've got the rubber ST matting in. No problems yet.
Old February 25th, 2005, 02:27 PM
arbik
Arbi Karapetian
oh, I guess I should mention.
The sound insulation I'm using, is the fluffy material they use under the carpet, with the aluminuzed mylar sheet on the top. I'm not useing any of the whazoo insulation parts.
I got mine for $13 from Pep Boys Auto Part store. I'm also not planning on glueing it in.
Just a few places to hold it in place.
Question..is it good to fold it to shape? or cut it and make separate pieces for the bed and wheel wells.
Also, did you cut the parts where the rear jump seats mount, or just drill holes and mount the seats on top of the rubber?
thanks,
-arbi
mats, rubber
brand new genuine lr rubber floors mats mattdh For Sale - Parts 4 July 6th, 2005 01:36 AM
diff guards and discovery rubber floor mats ToaDisco For Sale - Parts 5 June 5th, 2005 10:54 PM
used rubber floor mats and carpet mattdh For Sale - Parts 4 March 14th, 2005 07:51 PM
D-90 and 110 Front Rubber Mats Mike M The Vendors Loft 0 November 4th, 2004 09:39 AM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
