Any issues with plugging heater lines? - Defender Source
Old July 15th, 2013, 07:59 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm gearing up to install my AC set up and my first step is to make room. I would like to remove the old heater core and plug the coolant lines that supply it. Will that cause any issues with the cooling system? Or should I connect them to each other?
Oscar
Old July 15th, 2013, 08:41 PM
Connect them too each other to allow the water to flow round the engine.
Old July 15th, 2013, 10:01 PM
BlackField's Avatar
BlackField
Oscar
D110
Makes sense, I was just being lazy not want to track down an appropriately sized splice but I guess I can just hack it off the old heater core since its coming out anyway.
Old July 15th, 2013, 10:28 PM
I just used some copper pipe ... Few inch off cut.
Old July 15th, 2013, 11:08 PM
BlackField's Avatar
BlackField
Oscar
D110
Boom
heater
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
