Any ideas? Should I be worried? - Defender Source
Old May 5th, 2009, 10:01 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Alright I'm not really worried but I wonder if anyone here has any ideas as to why:
So first of all the indicator light for my emergency brake doesn't work... hasn't worked since I got it. You pull the emergency brake, it stops the truck but indicator light on the dash.
So I'm doing some moderate wheeling on the weekend and descending through a rock garden so I've got it in locked low and second gear when my brake light indicator flickers to life and comes on. I double checked the emergency brake to ensure it was not in fact pulled and continued my descent. I found that if I could accelerate on flat or slight uphills the light would go off again but any time I was working on a slow descent it would flicker to life again....
any ideas on where I'm getting a connection?
Old May 5th, 2009, 10:08 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Not to worry, handbrake has a little switch which engages when you pull up on the handbrake. Check wires - either loose wire or bad switch.
Old May 5th, 2009, 10:19 AM
JRW's Avatar
JRW
94 D90 ST #1247
I know I am stating the obvious, but it sounds like an electrical short. Looking at the wiring diagram it is a straight shot from the parking break switch to the light.
Monkeyboy
Guest
Posts: n/a
Check the fluid level in the master too.
Old May 5th, 2009, 10:42 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
second keith
pendy's Avatar
pendy
jim pendleton
89'd90
Yes thats whats wrong
legend in my own mind
Old May 5th, 2009, 10:51 AM
Also, not necessarily wrong. Depending on the angle it can trigger the light even if it is at an appropriate level. My lotus does this one turns.
Old May 5th, 2009, 06:10 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
mine did the same thing...remove the boot at the brake lever (slides upward, carful not to tear) and you will see the wire/switch whick makes contact when you pull up on the handle. Mine was loose, I sprayed contact cleaner into the switch, pinched the wire connector for a tighter fit, and tightened the fastener...works.
good luck
Old May 6th, 2009, 08:16 AM
btate
Bryan Tate
d90
yeah, my mcclaren f1 does that around 190mph, kinda annoying
Old May 6th, 2009, 10:21 AM
bharris's Avatar
bharris
Brad Harris
when accelerating through 190, decelerating from 190 or just an indicator that you have now reached 190?
Bumper Sticker Ideas chris snell Misc. Chit-Chat 46 November 18th, 2005 08:02 AM
sway bar ideas redrover Defender Technical Discussions 10 October 1st, 2004 09:56 PM
Ideas on building a 110 draaronr Defender Technical Discussions 4 July 14th, 2004 09:59 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
