Any guess on whats making this sound - Defender Source
Old July 31st, 2014, 03:53 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
Its been hot here in Orange County and a few times when I have gotten home from work running the a/c on full blast when I park the truck and get out there is a loud popping sound? it goes on for a while 5-10 minutes and i swear it sounds like its coming out from the pass front wheel? Its weird and I wonder what could be making the sound
https://www.dropbox.com/s/3l5mkt1nfl...%2012%20PM.mov
Old July 31st, 2014, 04:04 PM
I can't listen to that right now but it your description sounds like fuel expansion causing your gas cap to release the pressure. I've seen that happen before on vehicles.
Mark Kellgren
KM4BOR
Old July 31st, 2014, 04:07 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Cooling system depressurizing? Any other cooling system related issues? Running a little warm? Hows the coolant level?
I did not listen to the video (I'm in the office with no speakers) so just taking a few WAGs.
Old July 31st, 2014, 04:15 PM
Sounds like metal on metal. Something in the suspension or something steering wise is hot and clunking as it's cooling off against something else metal. You have got to love these machines!
Old July 31st, 2014, 04:30 PM
ok, I read your description too fast and missed right front, so not the gas cap.
I listened to it, that is weird. As irregular as that pattern is, and def a metal sounds, it's either something hanging that is still swinging and banging on something, or metal that was really hot and cooling (like in your cats if it's a v8).
After it stops, if you shake the vehicle from side to side, does it start up? if not, then I'll rule out something swinging.
The only thing left then is movement related to cooling contraction.
Mark Kellgren
KM4BOR
Old July 31st, 2014, 05:24 PM
Only when AC has been running?
Old July 31st, 2014, 05:27 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Does sound like exhaust cooling; could it be the abs pulsing?
Old July 31st, 2014, 05:34 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
shaking the car does not cause any sound going to run the a/c on the way home and see if I can get the sound every time I run the air
I kind of thought it might be ac dripping on the exhaust but it really sounded like it was coming from the wheel?
Old July 31st, 2014, 06:05 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Antichrist!!
I drive a f150 as a work truck and the ac drips on the exhaust and it doesn't sound like that, it could be but you say wheel. Are the brakes getting hot?
Old July 31st, 2014, 06:33 PM
install any new exhaust components lately?
Old July 31st, 2014, 06:43 PM
transientmechanic
1972 SIII
Listened to it at home now. That's definitely hot metal contracting. Cats maybe.
Old July 31st, 2014, 09:28 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I finally listened to it. Cats usually are more tinny in sound.
Do you have access to a mechanics stethoscope ?
Black Rhino Lives Matter
Old July 31st, 2014, 10:13 PM
Is the exhaust manifold, down pipes, etc all tight?
Old August 3rd, 2014, 08:05 AM
solarguy's Avatar
solarguy
Abraham Bell
Did you figure out this noise ?
Old August 3rd, 2014, 02:21 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I had mine on the lift yesterday, changing the oil, and I heard the same loud dull tapping. Came from way up on the driver side wheel well. I went to seek it out, but it subsided before I could isolate it.
Another Guess the Curb Weight thread! Buckon37s Misc. Chit-Chat 33 September 3rd, 2010 01:25 AM
Guess the part tkavan01 Misc. Chit-Chat 12 February 19th, 2007 11:53 AM
Guess the curb weight of my truck and win! btate Misc. Chit-Chat 50 December 23rd, 2006 01:34 AM
Well, that explains the grinding I guess... Trigger Misc. Chit-Chat 2 November 25th, 2005 11:44 PM
Any issues with putting sound insulation underneath rubber mats? arbik Defender Technical Discussions 3 February 25th, 2005 02:27 PM
