Any fuel in the tank dummy - Defender Source
Old March 25th, 2012, 06:58 PM
bikerblock
Kelly Block
1994 D-90 #1138
Talking Any fuel in the tank dummy
I was down to a 1/4 tank so I thought I would add some seafoam and a little ATF to lube the fuel pump. I headed out to for a little drive and the engine started to hesitate and loose power " I thought now what" I turned around and went back home, engine was running rough and not much power. So I change the spark plugs and it runs better well off to the gas station to fill it up It started running worse and 2 blocks from the gas station it dies, gauge still shows just under 1/4 tank. needless to say with fresh 91 octane and a full tank it runs better than ever. Moral of this story is make sure you have fuel.
Old March 25th, 2012, 07:52 PM
And read instructions? Glad everything worked out
fuel
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
