anti-sway bars? - Defender Source
Old July 11th, 2005, 10:49 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
anti-sway bars?
So I am thinking that I want to take off my rear anti-sway bar. Will I notice much difference ON the road? I have 33`s, and a 3" lift. Should it matter at all? I figure that the bar is more trouble than it is worth, to take off and put on etc etc. Any difference on road?
-Nathaniel
Old July 11th, 2005, 10:57 PM
Ditch it. It only took Chris and I 20 minutes to take his off at the campground, most of that time was spent looking for the right tools and stuff.
Old July 11th, 2005, 11:04 PM
oldscratchggf
nate
95 d90
Will there be ANY difference on the road though?
Old July 11th, 2005, 11:07 PM
Maybe, but I would guess very little to none, this has been posted a bit before I'm sure if ya search around you'll find your answer.
Old July 11th, 2005, 11:10 PM
Mike,
Any issues with the brake line (Is it long enough with full extension)?
Do your rear springs ever pop out?
Old July 11th, 2005, 11:14 PM
oldscratchggf
nate
95 d90
I just want to make sure that I am ready for any changes in the way it may drive, but I guess I`ll find out. Thanks though.
Old July 12th, 2005, 01:55 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
You'll feel a little more body roll in the rear but not much. If you take the front off there is a bigger difference. Ditch the rear, you'll get used to it in a day. Also take the front off and go wheeling... you'll be impressed.
I connect the front for long trips under load, it feels safer on the highway. The rear is useless.
Steve
Old July 12th, 2005, 06:38 AM
scoloco's Avatar
scoloco
'94 D90 ST
The rear was kinda flimsy when I pulled mine off. I doubt it will make much difference. Now the front one - that was much more beefy and a bigger difference. Took them both off and gave them away. There is a little bit more body roll, but nothing you cant get used to.
Note: I dont drive this thing like a sports car! Its a relatively underpowered truck
Old July 12th, 2005, 08:01 AM
Originally Posted by javelinadave
Mike,
When I bought mine it dodn't have an sway bars, I have longer break lines anyway (they are less then $100 for all 3 anyway). And the springs drop out all the time, I have cones in the front and back.
Old July 12th, 2005, 08:42 AM
I have neither sways on my truck and dont notice any difference that matters. The truck leans more, but it sure doesnt feel excessive at all. The only wierd thing is the truck will lean left or right if I'm parked on a side slope.
Old July 13th, 2005, 09:45 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I have had my rear off for a couple of months and noticed about 15% (pulled that number out of my ass) more roll. The amount of roll you get will depend on how stiff your springs are. Obviously the stiffer the spring, the less roll. I have not had a problem with the spring coming unseated. This will depend on your shocks, if you have longer shocks or EE shock mounts, it may. Get EE rear spring retainers, they're awesome. I just took off the front bar, but have yet to drive it as the truck is getting a new engine+. I have new slightly longer shocks in the front and was worried they would come unseated. I had a cone added to the bottom spring seat to keep it from being a problem.
Old August 3rd, 2005, 12:57 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Been running without for a while. I might put on a front sway with quick disconnects soon.
Anyone know if there are cones made for the 110? Been told that the 90 cones don't fit the 110 rear springs....
Old August 3rd, 2005, 01:09 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
D110 rear cones are bigger than D90, we have them in stock.
John C.
Old August 3rd, 2005, 01:28 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I will post a pic of my cones later!!
Old August 3rd, 2005, 05:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a 3" lift and 35's with no sway bars at all. I have no problem.. Like stated earlier, its not a sports car.
Legend in My Own Mind.
Old August 3rd, 2005, 09:06 PM
I drove a ST with no sways ~3" and 35" I think the guy was running ranchos in the rear with a RW cone setup and fox shocks up front it wasnt a bad ride a little more roll than my stocker SW with front sway bars.
Old August 3rd, 2005, 10:58 PM
sheki's Avatar
sheki
David Shechter
Just took my fronts off, no big difference. If you take a turn too fast you can feel the roll, but for the added articulation it is completely worth it.
Old August 4th, 2005, 02:23 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
It is worth pointing out that the only country where Land Rover sells its curious cars that it chooses to put anti-sway bars on its products, is the US. That should tell you whether you need them at all. In our litigious society where everything that happens to us is someone else's fault we apparently need anti-sway bars. It is exactly that which brought us the Wrangler when the CJ was superior off the beaten path. If you never drive your truck off-road...leave the anti-sway bars on....if you can take responsibility for your own well being....take them off, throw them away, and enjoy your super off-road truck.
Wherever I go...there I am.
Rear anti sway bar available Chaucer For Sale - Parts 3 December 29th, 2009 07:21 PM
Sway Bar Disconnect mdmccallum Defender Technical Discussions 12 December 15th, 2004 08:20 PM
Used Front/Rear Set of D90 Sway Bars kpracer For Sale - Parts 0 July 22nd, 2004 01:44 AM
sway bars needed bigrenna Wanted 3 June 3rd, 2004 08:42 PM
Stiffer sway bars? Do they exist? P1CR Defender Technical Discussions 4 December 5th, 2003 07:00 PM
