Anti-seize on 300 tdi glow plugs? - Defender Source
Old January 16th, 2016, 12:53 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Thought the ones I pulled out might've had a bit, any reason not to?
Also, let's talk torque settings
Valve cover gasket? How many pounds for the bolts, I wouldn't expect glow plugs to have a torque requirement but if you know pass long the information.
Getting my truck ready for a Maine shine run this week
Old January 16th, 2016, 01:16 PM
They use the threads as the ground path, so it would not be a good idea. The threads usually do not get stuck. The usual failure method is the tip breaks off and is stuck in the head beyond the threads.
As Briggsy says, read the manual for all the torque settings.
Old January 16th, 2016, 03:21 PM
Departing90
Sasha
95 D90
I use dielectric grease very sparingly on all spark plugs / glow plugs "threads" / light bulbs / battery terminals / fuses ..... anything electrical. Its "designed" not to interfere with elec conductivity and stop corrosion. Expensive stuff and you dont need a lot of it. Its colorless and has the consistency of regular grease.
FS TDI Glow Plugs, 200 - 300TDI rdavisinva For Sale - Parts 152 November 13th, 2017 09:47 PM
Anti-Seize bjf Defender Technical Discussions 23 March 25th, 2011 09:08 PM
WTB 200tdi Glow Plugs d90frank Wanted 0 August 1st, 2010 01:51 PM
300 TDI needs new glow plugs. Bosch or original Beru? sundogcwolfe Defender Technical Discussions 11 December 17th, 2009 10:36 PM
300Tdi glow plugs artm Defender Technical Discussions 9 November 21st, 2004 12:10 PM
