Anti-Seize - Defender Source
Old March 25th, 2011, 02:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anti-Seize
I was wondering what everyone uses for anti-seize. I have used this crap for years
http://www.permatex.com/products/aut...ubricant_a.htm
but I hate how I spend more time cleaning it off of everything than actually using it. It is beyond messy and sucks to get off paint. Is there anything better and less messy?
Old March 25th, 2011, 02:14 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
where do you use this?
Old March 25th, 2011, 02:16 PM
dchapman
Daniel Chapman
1999 D1
That's what I use. I have some in a spray can, too.
...don't know how you get it on your paint, though.
Old March 25th, 2011, 02:25 PM
tjfslaughter
thomas
Burbon
I use a lot of this http://www.loctiteproducts.com/p/10/...r-Blue-242.htm
I have not had problems with it on any of my trucks.
Old March 25th, 2011, 02:29 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I'm on my second tub of Copper Ease. Given the insane level of road salting that goes on in the UK, glopping this stuff on is the only way you get to use wrenches to remove fasteners instead of an angle grinder.
Tony
1984 110 "Smokey" (sold)
Old March 25th, 2011, 02:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
Aren't antiseize and locktite the opposite product? I have used it in various places but things that come to mind in-particular are the cage bolts on my nas 110 and hinge bolts on my 90. Even if you get a tiny bit on the paint it makes a mess.
Old March 25th, 2011, 02:39 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Brake Clean removes that stuff from the paint....
How do you get it on the paint anyway? How much are you applying? I keep an acid brush in my can and apply a small amount to the threads and everything is fine.
I'll write you an instructional manual on how to apply anit-seize.....
What tree?
Old March 25th, 2011, 02:41 PM
TS888's Avatar
TS888
Tony Sims
1984 110
That's not anti-seize, it's seize.
Tony
Old March 25th, 2011, 02:42 PM
bjf's Avatar
bjf
barry f
94 ST #395
Please provide a detailed manual. I like to brush it on nice and thick and pretend that the replacement bolts wont rust in the same manner as the originals. They literally rust looking at them. I replaced every bolt on my nas 110 cage with genuine bolts. Less than a year half were rusting.
Old March 25th, 2011, 02:45 PM
tjfslaughter
thomas
Burbon
In my last job.... I hand built about 20+ prototype trailers for the US military... When we where not using stainless lock-nuts we had to use this thread "sealant". It is much different then a permanent thread locker, like locktite RED.
Read the specs and you will see it has corrosion resistance. It creates a nice barrier. After tesing trailers in the corrosion chambers, cold chambers, heat chambers, vibration tables at Nevada Automotive Test Center and Aberdeen Test Center, etc.. this stuff held up, and you where able to take out the bolts and there where not siezing.
Bathroom Reading: http://www.woodencrates.org/standards/MIL-S-46163.pdf
Old March 25th, 2011, 02:47 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
YGM homey
What tree?
tjfslaughter
thomas
Burbon
I think it falls into the category of "sealants with corrosion resistance"
Old March 25th, 2011, 02:49 PM
NoVaKevin
Kevin
sold#1469
two letters
Old March 25th, 2011, 02:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
I wonder if you could use it to abate the corrosion on that rusty delaminating crossmember of yours?
-Jeff
Was planning to just smear it all over the inside of the crossmember. I received all my eastwood crap to fix that. Hoefully the truck wont turn to dust before I start.
Old March 25th, 2011, 02:56 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
this is what we've been using for years for marine vehicles and robotics. It's phenominal as a lubricant - but we've found it is better than any anti-sieze we've used - particularly for stainless on stainless which is notoriously fussy. Also, for corrosion reason, introducing certain second or third metallic agents (copper and zinc being in many anti-siezes) can cause bigger issues for us.
in some ways it is less nasty clean-up wise than metallic anti-siezes - but being a waterproof grease, it's a bit gooey. We call it Gumby Cum (it's Gumby green) or the Devils Lipstick (never comes off)...
http://www.aogrepairs.com/index.php?id=95
Old March 25th, 2011, 03:07 PM
Naplm00
Matthew
I use both the copper and the aluminum kind...They are both messy.
I use the aluminum stuff on anything that is not subjected to high heat like brake caliper bolts, suspension components ect.
The copper stuff goes on exhaust studs and nuts, brake pad sliding pins, engine accessories
Old March 25th, 2011, 03:08 PM
california
Geoff M
Barry's neighbor hates him so throws a bucket of salt water on them every night...
Old March 25th, 2011, 03:27 PM
tjfslaughter
thomas
Burbon
Has anybody explored Titanium. http://store.mettec.com/category/238
I am not sure the strength comparisons..
Old March 25th, 2011, 03:37 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
What Carey said. Brake cleaner takes it right off. You do buy a case of brake cleaner when Advance Auto Parts has it on sale, right, Barry?
Old March 25th, 2011, 03:43 PM
tjfslaughter
thomas
Burbon
He has to buy that California compliant cleaner... It probably gets you high but for the most part it is useless
Rear anti sway bar available Chaucer For Sale - Parts 3 December 29th, 2009 07:21 PM
New Anti Rock setup for d-90 dmarchand For Sale - Parts 4 September 18th, 2006 11:54 AM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
Anti Roll Bar Joints TDI Guy For Sale - Parts 3 December 17th, 2004 08:05 PM
