Anti-freeze in cylinders - Defender Source
Old January 29th, 2006, 01:35 PM
boxerhips
Tim Riccardi
1995 d90
I just removed the heads from a 4.6 that I was given and there was anti-freeze in all pass side cylinders. The engine was removed for loss of compression. The waterpump shaft came off while driving on highway. I was told the driver pulled over as soon as it happend. The drivers side is fine. When I check the heads with a straight edge there is about a 1-2mm gap in middle, also the middle head bolts were really tight. The block does not appear to have drop a cylinder sleave, they are flush. None of the cylinders look stream cleaned, they all look the same. I've had a head gasket go before and you could see a noticable leak from water to piston, I can't fine anything on this engine. Should I have heads pressure tested? I don't have to use they, but that might tell me if the block is good. I've heard the heads never crack, just warp, is this a correct statement? The engine oil and insde the block looks fine. Is there a way to check block? Tim
Old January 29th, 2006, 10:12 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
WOW thats alot for a head. If there are no cracks in the head it should be fine once it is milled. Do both not just one! I do not know how to check an aluminum block, as I have no experience rebuilding them.(yet...knock on wood).
--Benjamin Franklin
Old January 29th, 2006, 10:52 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Ok,
to warp a head that much the engine severely overheated. I don't think you can safely cut that much material off of the head without 1) seriously affecting compression, 2) seriously having pushrod length problems, 3) having serious intake mismatch. These blocks are known for having problems cracking behind the liners and causing mysterious coolant loss and overheating. I recently had a customer with a D2 seriously overheat. I recommended a longblock. They declined and opted to have the heads pressure checked and cut and new head gaskets installed. The car immediately began using small amounts of coolant and eventually began coolant fouling #5 even though the heads checked out and there was no apparent block damage. I recently put a used 4.6 into the car.
I would be very careful about how much money and time you sink into this motor. A good 4.6 is worth a fair bit of money. I suspect there is a reason it was free... My advise is to pull the crank, rods, and pistons and find a known good block to put them in. The bore size of the 3.9, 4.0, and 4.6 is the same. It is the internals that make it a 4.6. Ideally look for a cross bolted 4.0 or 4.6 block. As a last resort I would use the one currently in the truck.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 30th, 2006, 12:59 AM
boxerhips
Tim Riccardi
1995 d90
Rob Can you install a 4.6 crank in a 3.9 block?
Rob Can you install a 4.6 crank in a 3.9 block? I was eyeing the heads with a square, not a calibrated strait edge. I will take head to machine shop to check. Tim
Old January 30th, 2006, 01:38 AM
Roadsiderob
Robert Dassler
1994 D90
Tim,
I believe the crank/rods/pistons from the 4.6 will fit the 3.9 block. If possible, I would look for a 4.0 or 4.6 cross bolted block first, as the bottom end will be stronger. I have done several 4.6 swaps using the original 3.9 front cover & distributor. I usually use a Crane cam, lifters, and roller timing chain. The 3.9 oil pan will work but you may have to 'clearance' it for the front crank throw. It's a nice running engine.
If you are planning to put the engine in your D90, I would not mess with a set of badly warped heads. I would have the 3.9 heads rebuilt and use those. A good machine shop should be able to check the block for you. Basically it involves sealing the cooling system and pressurizing it to about 30psi and then looking for air leaks (use soapy water). I would be wary of the block. The cooling passages are on the front & rear of the block...none in the middle...if the middle cylinders had coolant in them, there is a serious problem somewhere. For the heads to be that visibly warped, the car had to have been driven in an overheat condition for a while. "Pulled over as soon as it happened" probably really translates to "pulled over as soon as I happened to find the nearest Starbucks so I could have a latte and use the little girls room while I waited for a tow". Ask me how I know this!;o) Waterpump shafts do not just fall off...it probably made noise and leaked and got hot for 100 miles before it fell apart. These engines are relatively expensive to build and I wouldn't take too many chances investing time, money and parts to rebuild questionable components. The guts are the important part and getting them for free is fantastic. Good luck with your project.
Almost forgot...you'll need a spacer to make the 3.9 pulley work with the 4.6 crank. I had a bunch of spacers machined out of old crank gears and still have a few left.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Rear anti sway bar available Chaucer For Sale - Parts 3 December 29th, 2009 07:21 PM
Looking for a front anti sway bar Chaucer Wanted 9 August 24th, 2009 07:49 PM
Rear anti rock redrover Misc. Chit-Chat 11 March 22nd, 2005 08:43 AM
110 Wheel Cylinders - How often do they fail? COSteve Defender Technical Discussions 7 March 11th, 2005 04:27 PM
Anti Roll Bar Joints TDI Guy For Sale - Parts 3 December 17th, 2004 08:05 PM
