Antenna Options - Defender Source
Old July 20th, 2008, 10:31 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Antenna Options
I had to move the antenna on my '94 over to the passenger side to make room for the snorkel. In the process I could tell the wiring for it was getting ready to crap out. Long story short, what is the best replacement option? Has anyone installed a power antenna? How about those shorty rubber antennas? Looking for the best reception for the size. Thoughts?
Semper Fi!
Old July 20th, 2008, 05:16 PM
I have one of those short rubber ones on my 110 and it works fine.
charles
Old July 21st, 2008, 08:56 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Satellite radio.
Jimmy Buffett
Old July 21st, 2008, 09:59 AM
x2 on short rubber duck antennae, works fine.
Old July 21st, 2008, 11:13 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
x3 on short rubber, happy so far.
- Charles Eames
Old July 21st, 2008, 03:28 PM
Wolf Fabrication
Sterling Archer
'08 D3
I think I may need to go with a shorty rubber antenna anyway - it doesn't seem like anyone sells the old skool steel antennas anymore!
Semper Fi!
Old July 21st, 2008, 03:31 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Since you will be drilling, you could install any antenna you wanted, right?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 21st, 2008, 03:32 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
Hi,
Don't buy an antenna at all....If you have a CB in your truck, the coaxial cable that runs to the CB antenna is usually 18' long and you can tap into that cable for your FM reception. I installed a simple CB / FM splitter unit at the back of my CB so I can use my cb anntenna and the 18' of coaxial cable as a standard FM antenna. My FM radio works fine even without the cb FireStickII antenna. You do have to tune the antenna with a SWO meter to optimize CB reception. But the 18' of Coaxial that snakes it's way through my truck works great as a FM antenna all by itself.
Old July 22nd, 2008, 01:35 PM
Wolf Fabrication
Sterling Archer
'08 D3
I already drilled a hole and installed the stock antenna, but the wiring for it has crapped out.
I am still a little ways from installing a CB antenna, so I will just cheap out and get a shorty rubber one.
Semper Fi!
CB Antenna Splitter bjenk Defender Technical Discussions 2 March 28th, 2005 08:45 AM
Antenna Wanted For 95 D90 Rockhead12 Wanted 2 January 12th, 2005 06:12 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Aftermarket distributor options. draaronr Defender Technical Discussions 1 September 29th, 2004 07:30 PM
