another whining question, but different - Defender Source
Old June 4th, 2012, 10:09 AM
wantone
Rick Thompson
94 ST #1222
another gearbox whining question, but different
hello gents! just got my rebuilt r380 from ashcroft plus a new t case input spline and had them press on new bearings. replace the bearing races in the old t case for the new bearings as well. and a new clutch and had the flywheel turned. all works well, it does shift a bit more tighter (as to be expected?) but it seems to have a bit of a whine now. now, i do believe i had a bit of a whine in 3-4 gear when just crusing along, not on the gas but easy crusing, you know, when you are hardly on the gas. so the whining i have now is the same but it does seem to do it when acclerating a bit. could this all be due to the new parts? btw, it got replaced because the splines sheared.
thanks
ps. ashcroft is a super company to deal with, very pleased!
Old June 4th, 2012, 11:21 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
from the Ashcroft FAQ's. After I had my R380 rebuilt with the new gear in the t-case, it whines a bit as well.
I have just fitted a new cross drilled input gear to my LT230 and it whines, is this normal?
Some "pattern" gears are not "crowned" during manufacture and will whine because of the edge contact this creates
http://www.ashcroft-transmissions.co...&productId=219
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 4th, 2012, 11:25 AM
wantone
Rick Thompson
94 ST #1222
thanks! that is what i figured. now i can email dave and tell him to forget about my question and how i should have checked the website first....
Old June 4th, 2012, 11:30 AM
Are you running redline MTL in the R380?
My guess is the whine is from the LT230, but in any event I like adding a half a bottle of lucas to the LT230 to shut it up.
Old June 4th, 2012, 01:36 PM
wantone
Rick Thompson
94 ST #1222
yes, redline mtl and redline 75/90w in the t case. lucas oil stabilizer? how much? should i drain out some of the gear oil and top off?
Old June 4th, 2012, 03:00 PM
I just wait for it to leak out. I would personally drive around for a few thousand miles before pronouncing it permanent -- the whine that is.
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
