Another weird turn signal question - Defender Source
Old March 5th, 2009, 07:11 PM
minorthreat
Lance
1997 LE, 1997 Black ST
I couldn't find the answer in the archives so here it goes:
My right signals work fine. My left signals do not, but I hear the relay click when I click on my left signals. When I put on the hazard switch, all signals work just fine.
Any ideas as to what this could be?
(Incidentally, I have the ECR LED's now, which I installed today.)
Old March 5th, 2009, 07:36 PM
Do you mean you had the problem before and after the install, or just after it?
Old March 5th, 2009, 08:10 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
That would point to an issue with the switch/ contacts.
Email me if you need assistance.
Email:
Old March 5th, 2009, 08:21 PM
minorthreat
Lance
I had the problem before (left side signals failing), periodically, but without the relay clicking, and it mysteriously worked itself out after a few days. The past few days, however it was doing that, and also sometimes just the rear left signal would fail (creating the rapid front signal). It was a nice day today so I decided to install the LEDs, figuring that maybe a funky bulb connection was the culprit.
I must also add everything was working just fine just before the install.
So... after the install... I have perfectly functioning right hand signals. Also, all signals, left and right work when I put on the hazard switch. But when I switch on the left signal, the dash lamp does not light, nor do the left hand signals... I just get the click of the relay.
I assume there is a loose connection somewhere, but I guess I could use some thoughts on how to go about finding it.
Old March 6th, 2009, 07:27 AM
ECR's Avatar
ECR
Sounds like a switch issue.
Unplug the switch and make the connection manually with a short piece of wire to see if it works.
If not, plug the standard lamp back in, or swap the signal LEDs side to side to see if the problem changes or goes away.
Are you using our LED flasher unit?
If the LED unit has an issue we will be happy to replace it.
Email:
Old March 6th, 2009, 11:09 AM
minorthreat
Lance
That's gotta be the the problem. Last night after I posted, I got into my truck and the signals worked fine. It has a mind of its own. I'll check the contacts today, and hardwire them if I have to.
Mike, I'll send the lamp to you next week. First, I'll take a look at it again to make sure my eyes weren't playing tricks on me.
Thank you for your help.
Old October 2nd, 2009, 02:52 PM
Eddie Haskell
Aaron Haskell
1995 D90SW w/ ECR 4.6
Was this ever resolved? I have the exact same problem with my truck and would like what your remedy was.
Thanks!
EH
Old October 2nd, 2009, 07:27 PM
ECR's Avatar
ECR
If you are running ECR LEDs they do really odd things when the front turn signal bulbs burns out.
I just went through this on a 90 here. LH signal worked fine, RH signal made all hell break loose. Turned on the hazard and that worked fine. Problem was I was just looking at the back lamps when the hazards were on. When I looked up front I saw the RH turn signal bulb had burnt out. Changed the bulb in the front and everything was 100%.
Its a back-feed issue with the LED low load flaher unit.
Have to admit it even made me wonder for a few minutes, but check the standard bulbs at the front and their grounds.
Email:
Old October 2nd, 2009, 07:31 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Excuse me for my ignorance, but I presume ECR is the genuine Mike Smith?
Robert Deniro
Old October 2nd, 2009, 07:35 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
we should hope so
Old October 2nd, 2009, 07:43 PM
ECR's Avatar
ECR
Nah, never heard of the guy.
Email:
Old October 2nd, 2009, 08:04 PM
madcowdungbeetle
Carter
I had a similar behavior with my D90, it ended up being a slightly corroded ground in one of the tail lights.
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
turn signal question andyrad Defender Technical Discussions 17 August 24th, 2008 11:21 AM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
