Another Snapped Timing Belt - Page 4 - Defender Source
Old December 13th, 2012, 07:44 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Pictures for science.....
ID:	62709   Click image for larger version
psykokid
Jake
1997 Disco
shouldnt the crank timing belt pulley be held into place by the crank pulley for the belts once everything is assembled and torqued down? Maybe try putting both pulleys on and see how things sit. Dunno, thinking out loud..
Old December 13th, 2012, 07:48 PM
navydevildoc
Neill Thornton
Pics of head with old gasket still on....
Old December 13th, 2012, 07:51 PM
navydevildoc
Neill Thornton
Yeah, that's what I thought too. I am gonna put the crank timing gear on, and then the pulley, and see if there is any play. The rear lip of the timing gear is so thin it's almost razor sharp... so it only takes a minuscule amount of movement to make things go bad.
Old December 13th, 2012, 08:40 PM
http://www.aulro.com/afvb/technical-...t-but-why.html
http://www.aulro.com/afvb/good-oil/4...ming-belt.html
Seems that the factory manual torque setting is too high.
Old December 13th, 2012, 08:46 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Already discussed earlier in the thread. I have the Diff Lock article.
Old December 13th, 2012, 09:10 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Some aftermarket tensioners don't need the spacer/washer used behind the factory one, any chance it was left in there and was rubbing on the inside of the front cover?
Old December 13th, 2012, 09:31 PM
Sorry Carl, my bad.
Old December 13th, 2012, 11:43 PM
navydevildoc
Neill Thornton
Hmmm.... those AULRO articles mention overtensioning a lot, something I also thought of... it's hard to check the tension after you start to turn the wrench to tighten the bolts... as you tighten the bolts you inevitably raise the tension on the belt.
But, with all the disassembly complete, I will spend tomorrow scrubbing old gaskets and seals off and then start putting it all back together again...
Old December 14th, 2012, 10:11 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Work with hands free and the exact pressure on tensioner pulley:
- Charles Eames
Old December 14th, 2012, 10:16 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Then run your engine without the cover to see how the belt is doing:
- Charles Eames
Old December 15th, 2012, 07:27 PM
navydevildoc
Neill Thornton
Well, everything was going well today as I put the engine back together. I had cleaned the head and block surfaces real well using some 3M Roloc plastic bristle brushes, put on the head with the new gasket and bolts, everything was looking good.
Then I went to put on the first glow plug. The book said to torque to 20 NM. So, me being anal breaks out the torque wrench. Made it to about 15 NM before I feel it give way.
FUCK MY ROVER-GOD-CURSED LIFE. The glow plug has stripped out the head.
So now here I am, having already used the gasket and bolts to put the head on, and a fucking useless hole in cylinder 4.
So now I am sitting here trying to decide if I buy a new head or try and get aluminum helicoils and fix it that way. Either way I am now looking at having to buy a new gasket and bolts.
Old December 15th, 2012, 07:47 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Oh man...sorry to hear about all this. wow....
Old December 15th, 2012, 09:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sorry to hear Neill. That's some serious bad luck!
Old December 15th, 2012, 10:21 PM
damn. Those bolts can be used up to three times btw. But it's time for a new head. those threads are under compression. regardless, there may be some shavings in the cylinder now from the stripping.
That seriously sucks. The fact that your wife hasn't made you sell the D is a mystery to me, and speaks volumes to her.
------ Follow up post added December 15th, 2012 10:22 PM ------
If it's ANY consolation, your head and gasket is MUCH MUCH cheaper than mine. To the point of envy.
Mark Kellgren
KM4BOR
Old December 15th, 2012, 10:40 PM
navydevildoc
Neill Thornton
That's the awesomeness of being single ;-)
Old December 15th, 2012, 10:55 PM
navydevildoc
Neill Thornton
So now that I have gotten home, had a few excellent San Diego beers, and calmed down...
I am in a thought exercise. I basically have 3 choices:
1) Helicoil the glow plug holes. I might as well do all 4 if I am doing it. But as Mark noted, these threads will be under diesel compression forces. How well do helicoils hold up?
2) Buy a new head in stock configuration. Don't see one in the states, RN, AB/BP, RDS don't show them. Turner Engineering has a stock one for ~500 bucks plus shipping. RDS might have one, but George doesn't put a lot of stuff on line. I already have an e-mail out to him.
3) Since I am already looking at Turner, they have a "high performance" head that's 800 bucks. Don't know that it's worth it, but they have it.
What does the common wisdom say?
Old December 15th, 2012, 11:02 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
When in doubt, buy new. That's my motto. I'm slowly replacing every component with new counterpart.
What's the difference between a stock head and a high performance head?
Old December 16th, 2012, 04:22 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm sure someone this side will chip in. Used 300 tdi heads are relatively common over here.
------ Follow up post added December 16th, 2012 09:25 AM ------
That's bad.
If I can help...
Here's the Turner page for those that are interested.
http://turner-engineering.co.uk/html...anceheads.html
Turns out I live just down the road from them.
Mike Hammond
Old December 16th, 2012, 10:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You are my new best friend
------ Follow up post added December 16th, 2012 11:11 PM ------
Get a new head from Turner, take a pic of it, send it to me and I will go to a very good brujo I know close to the Haitian border and for a small fee we will cast some spells on it to break the curse .
Seriously, get a new head, but first walk away from the rover for two or three days.
- Charles Eames
Snapped timing belt on Tdi JFD Defender Technical Discussions 53 October 19th, 2012 10:36 PM
300Tdi Timing belt failure and repair.. TDI Guy Defender Technical Discussions 46 November 11th, 2010 12:53 PM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 12:23 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
