Another rivnut/ rivetnut post - Page 2 - Defender Source
Old June 2nd, 2010, 01:35 PM
Originally Posted by AmityD90 View Post
I'm getting a Troy Box for the back of my defender and I'm thinking it may be time to buy a rivnut tool for the install. Is there any reason why I should get a metric set versus a standard set? Not sure which one to get. Any recommendations? Not sure how much I will be using this type of tool, perhaps for a wing top install down the line so didn't want to go overboard on an expensive one, but don't want to cheap out either.
Thanks in advance!
I do everthing in metric as I like carrying only one set of tools, and as you add more on, I hate trying to figure out if a bolt is metric or SAE.
Old June 2nd, 2010, 02:08 PM
Just get the tool that installs M3, M4, M5, and M6. M6 will be fine for your box install, and the others will come in handy when you have to replace rivnuts for the hardtop install etc. Its like 70 bucks at mcmaster.com - order some extra aluminum M6 rivnuts while you're at it.
You will find uses for this thing once you've got it. Awesome tool.
Old June 2nd, 2010, 03:13 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Thanks for the suggestions. Metric it will be.
Old June 2nd, 2010, 03:33 PM
I am very happy with the one from northern tool in the first post. I called RN and had them send me a bunch of genuine land rover rivnuts and more genuine land rover rivets too.
Old June 2nd, 2010, 04:55 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi chaps i don't know how i have done without my rivnut tool for so long, used it to replace the seatbox inserts and repaired inserts for a mates storage box, also used it to replace all the nuts on my work bench.
mine is like this : http://www.uktools.com/riveter-rivet-p-1875.html
the long handles make squeezing the M10 rivnuts easy.
however with the one i bought the best results are when it has been set up correctly, however once set is great for doing lots of the same size.
my mate bought this one works well but need to buy extras to cover all the sizes: http://memfast.co.uk/shop/Vcat1.asp?cat=2258002340
the good thing with this tool is it allows you to get in tight places and is easy to set up.
regards all
Gren
Old June 4th, 2010, 10:55 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've been using these since the early 80's:
http://www.pegasusautoracing.com/pro...sp?Product=659
I don't need them often enough to warrant a special tool, plus a few collars and bolts take minimal space in my toolbox.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 4th, 2010, 11:52 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I haven't pulled the trigger yet on a set but I am leaning toward this
http://www.homeprofasteners.com/inde...pshop&Itemid=6
They sell this kit on ebay also.
then buying the aluminum nutserts from mcmaster.
Rebuild and Tdi Conversion Pix JimC Truck Build-up's & Restores 9 January 10th, 2012 04:58 AM
Can someone post naked dash pictures? Buckon37s Defender Technical Discussions 8 July 31st, 2005 06:19 PM
post a pic for me? mattdh Defender Technical Discussions 1 October 29th, 2004 12:22 PM
can't post a picture Campbell Support & Suggestions 7 June 3rd, 2004 07:44 AM
entire post not displayed artm Support & Suggestions 7 October 28th, 2003 09:14 AM
» Defender Registry
NEV
wanabewheelin
Rosco
Cal
Add your Defender
