Another rear bumper question - Defender Source
Old December 13th, 2010, 07:59 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Does anyone have detailed pictures of a bumper with side panel protection as well? I am trying to decide how I want to build rear corner protection. Don't know if I want it angled of if I want to cut the rear corner so the "slider" will be flat. Any detailed pictures of rear corner protection would be great. Thanks.
That is why it is called a short cut. If it was easy it would just be "the way."
Old December 13th, 2010, 11:38 PM
I built my own corner protectors
http://gallery.lhsw.com/view_photo.p...rs&id=IMG_0282
lots of pics here
http://gallery.lhsw.com/d90_rear_corner_protectors
Old December 14th, 2010, 05:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Very Nice! Can you make me a set for a 110?
Originally Posted by cgalpin View Post
Old December 14th, 2010, 06:45 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Built my own as well: http://www.defendersource.com/forum/...=23181&page=13
I angle mine so I could keep the same body lines.
Semper Fi!
Old December 14th, 2010, 07:22 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Thank you guys. It looks like neither of you trimmed your actual body panel. I am not wanting to cut the body, so these look like great ideas. I will probably do something like cgalpin because it will work with my bumper better. Did you use 1/4 plate for the actual corner guards? Does it have any give to it when you hit it on something? I was trying to figure out a way to use rectangle tubing like my sliders for the strength, but it is too bulky and I don't like the way it looks. The plate looks really clean. You both did a great job.
Old December 14th, 2010, 08:48 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Yes, thanks to both as I am thinking about doing something along these lines also. My factory bumper is pretty rusted out and I want to replace it but I am having a hard time buying one. So have been thinking of making something like Charles and then putting a class three in the middle so that I can put in a removable step. I need the step for my kids to get in and out. But then I could remove it when on the trail.
My Rover doesn’t leak oil, she is marking her territory.
Old December 14th, 2010, 08:54 AM
Martin, 3/8 is plenty and no there is no flex. Trail tested.
Tom, sure. I'll let you know when I'm in a financial position to make $1/hr
Michael if you poke around on my gallery I have pics of a center hitch I made too.
Old December 14th, 2010, 08:55 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Here is some pictures of a bumperette. It is designed to envelope the aluminum making up the rear quarter panel and attach using the existing bolt holes in the rear crossmember. This is the passenger side one.
ID:	33942   Click image for larger version
Old December 14th, 2010, 09:35 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
$1 an hour sounds a little rich, my workforce is payed in Pizza!
But seriously, i guess they are a bit labor intensive. They do look well thought out, and very nice!
Old December 14th, 2010, 09:46 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
This was what I came up with. The corner protectors are 1/4" angle iron that goes under the aluminum panel. The rear plate is also 1/4" with a 2" wide piece that covers the underside of the crossmember. The receiver hitch is 3/4" plate and everything is all welded together in one big piece.
Old December 14th, 2010, 09:56 AM
Damn, Jeff...looks great!
Old December 14th, 2010, 10:27 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Thanks Josh. I combined something like Retrofit's rear bumper and a version of cgalpin's bumperettes with the receiver I had previously made.
Old December 14th, 2010, 10:29 AM
Yes very clean Jeff. I like the full rear cover plate as well. Are the bumperettes integral or just bolt on as well?
Old December 14th, 2010, 10:57 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
It's all welded together. That makes me kinda nervous because if one corner does get damaged then the whole unit needs to come off. Hopefully is adds a bit of strength being all one piece though.
Old December 14th, 2010, 11:03 AM
Yes it should be stronger. I wonder about trapping moisture behind it though.
Just checked out your website - awesome sculpture!
Old December 14th, 2010, 12:12 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Thanks Charles!!
I was definitely thinking of that rusting out so I put 1/4" spacers between the plate and crossmomber to aid in draining and left a space on the bottom so I can hopefully pressure wash any dirt and debris out of the way to prevent corrosion. That is always a consideration when dealing with steel.
Old December 15th, 2010, 08:23 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Charles, I looked at the hitch stuff. That is exactly what I have had in mind. I just was going to make a step that fit in the reciever so it could be removed. Buy the way I can offer you more than a dollar an hour. Remember I got quite a bit of my front bumper built for beer.
Jeff, Really like the rear bumber you did, very clean. And the sculptures. Very nice. That rolling ball is amazing and beautiful. Well done!
Old December 15th, 2010, 06:07 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Another rear bumper
Greetings-
I attached a couple of pictures to hopefully show the side/bottom of my bumper with "hoop" style side protection. Rockware proud!
Hope this helps... good luck!
Jay
'94 D-90 #282
ID:	33994   Click image for larger version
Old December 16th, 2010, 10:58 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by genie90 View Post
Greetings-
Jay
'94 D-90 #282
I like it, I'm trying to get a buddy of mine to make me a rear bumper/tire carrier/Jerry can/hi-lift jack holder, maybe I'll see if he can integrate something like this too...
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old December 16th, 2010, 07:38 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I am thinking of putting my gas cans behind my tire like a rockware bumper. I am concerned about how far the tire will be sticking out. Anybody have an opinion on that. I could do it like the old SG bumper, but don't like the exposed gas cans hanging off the back of the truck. Just looking for input. I got the bumper built, and the corner guards, now I need to start on the tire, gas can, and jack holders.
decisions, decisions.......
bumper
Rear bumper or not? 97-D90-736 Defender Technical Discussions 59 May 18th, 2010 03:10 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
The great bumper question rustydefender Misc. Chit-Chat 4 June 21st, 2005 05:40 PM
OEM rear bumper mpodgorski For Sale - Parts 2 August 6th, 2004 06:19 PM
Rear Bumper bolts? Quimbola Defender Technical Discussions 2 July 16th, 2004 11:30 AM
