Another question? - Defender Source
Old January 9th, 2013, 08:56 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
Another question?
ok now i have a new one.
sounds like the transmission is making some strange noises......
in idle i hear a faint rolling noise and it goes away when i press the clutch in.
while driving it makes a little noise and when on the gas it will even make a chirping noise every few moments.....
this happens is 1s2, 2nd, 3rd, and 5th but NOT in 4th........4th gear is perfect.....no noise, nothing........
everything FEELS fine.....no vibration nothing.....
any thoughts on this?
thanks
Old January 9th, 2013, 09:14 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Throwout bearing?
Old January 9th, 2013, 09:17 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
Is that a it's definetly a throw out bearing or a maybe it's the throw out bearing?
What does this mean? Total rebuild? Fixable?
Should I stop driving the truck?
Old January 9th, 2013, 09:26 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
There is definetly no noises when I press in the clutch.
Old January 9th, 2013, 09:56 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
Hmmm haven't tried idling in gear.... Just normal driving.....
Old January 9th, 2013, 10:33 PM
If its just the throw out bearing, it will only make noise when the clutch pedal is pressed.
-Jeff
You sure about that? I thought the "hum" or "whistle" could be the throw out bearing on its way out. My started as a whistle when I'd press the clutch, but has progressed to a bit of a hum all the time. I'm pretty sure mine is the throw out bearing on its way out too. Or you think not?
Old January 9th, 2013, 11:02 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
I really have no idea. When I push in the clutch the noise definetly goes away.
I also read some land rover service thing online and it said if there was an issue with the lays haft? It would be present in 1,2,3 and 5th.... With little to no noise in 4th..... Has anyone heard anything like this before?
Old January 9th, 2013, 11:23 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
That was just my guess I have not seen it in person so no way to tell for sure.
Jeff,
In my experience the pressure applied to the throw out bearing causes the noise to change or go away. The noise can present differently.
Not that bad to replace fwiw
Old January 9th, 2013, 11:28 PM
Besides dropping the tranny you mean .
Old January 9th, 2013, 11:44 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
No need to drop it, you can just pull it back far enough to install the new bearing. Less stuff to disconnect that way
Old January 10th, 2013, 11:30 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I found in mine that the bearing was going bad and it made a noise only when the clutch was not depressed. I can verify that it was definitely throw out bearing as I removed everything and the bearing was melted!
To the point of not having to pull the trans, this would be tough as you would have to pull back far enough to get the throw out bearing off the input shaft...seems like at that point the transmission would be easier to just put on the floor rather than messing with supporting it while working. Plus, to me, it is worth making sure the clutch is in good shape.
Old January 10th, 2013, 02:06 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
My R380 has done that since I got the truck 2-3 years ago. It hasn't gotten better or worse. Recently I read (here, I think) something about why it makes the noise and that it's nothing to worry about. Unfortunately, the only thing I remember about it is the don't worry part.
John Karlsson
Hope Valley, RI
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
