Another overheating question - Defender Source
Old June 18th, 2009, 03:36 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
My 94 st seens to overheat when I drive in the city or am idling for a long time. It does fine (knock on wood) when I drive on the highway though. I checked all the hoses and replaced the thermostat but that still doesn't seem to help.
I recall reading a post about rolling up a newspaper and trying to stop the fan when engine is hot to see if it's a bad fan clutch.
Any info on this? And if so, are they easy to replace??
Lindy
Old June 18th, 2009, 04:32 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
This sounds exactly like what my 94 was doing even after full fluid change and new fan clutch.
This is the procedure, but if you do it wrong and chop a finger or hand off it's your own fault.
With the engine cold, start it and use a rolled-up newspaper to try to stop the engine fan - it should stop easily. Then let the engine get hot (meaning the engine compartment) and try to stop the fan - it should shred the newspaper. Diagnosis: If cold it shreds the paper, it is locked. If hot it stops the clutch has failed.
My problem turned out to be a radiator that road salt had destroyed so I wasn't getting any cooling. The radiator visibly looked okay until it was pulled from its frame during my engine swap and the fins disintegrated when touched. You may want to check the radiator before you go much beyond the fan clutch.
S-P
Old June 22nd, 2009, 10:54 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Thanks Sean.
I have added a tube of Redline wet wetter with no improvement. So now I have ordered a new fan clutch from autozone. It should be in tomorrow so we'll see if that changes things.
Old June 23rd, 2009, 05:18 AM
What part number from autozone?
Old June 23rd, 2009, 10:03 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Part number 922301.
cost: $119.99
Old June 23rd, 2009, 03:17 PM
Ive tried 4 of these and they dont seem to work, as in they dont seem to lock up when the truck gets hot.
Old June 23rd, 2009, 10:03 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I'll let you know if mine works properly. Will be installing it tomorrow.
Old June 24th, 2009, 07:13 AM
its a reversed thread, loosens to the drivers side.
Old June 25th, 2009, 07:52 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I installed the fan clutch today and (knock on wood) I haven't had any problems so far.
overheating
Overheating/ Diff Lock question icurnmedic Defender Technical Discussions 14 June 27th, 2006 06:06 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating Question Troys Defender Technical Discussions 8 August 11th, 2004 11:04 PM
