Another OME sided springs thread... - Defender Source
Old February 12th, 2012, 06:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm swapping suspension this week, from factory springs (7 years old now) to OME 751 and 764. Both set have an A and a B spring, A springs are half an inch taller than B springs.
A springs on driver side and be done with it ?
Cheers
- Charles Eames
Old February 12th, 2012, 09:51 PM
A lot of places have intentionally done away with (or should I say "undone") sided springs and keep them the same. Did you purchase already? I went with same sided springs when I just did mine this fall, I like it to sit level as-is.
Old February 12th, 2012, 11:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I have them waiting for me for quite a while now. I have some spare time this week, so I really should do it asap. I read somewhere that they cross the taller springs.
- Charles Eames
Old February 13th, 2012, 06:59 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
They handed the springs so that the truck would be level with the driver, RHD, in the truck. They didn't account for us LHD people unless you swap how they are installed, IE taller springs on the LH side. I have heard some people using spring idolaters on the short spring side and nothing on the other side.
Land Rover 110
Old February 13th, 2012, 07:52 AM
Ya Julien, I too have a set that's "handed". I'm gonna throw them under the SWB RRC along with those Bilsteins I got a while back so that it will pass inspection. I'm going to put the longer ones on the driver's side. If it lists to starboard, well, so does the Costa Concordia!
Old February 13th, 2012, 08:00 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone familiar with the diagonal method?
- Charles Eames
Old February 13th, 2012, 12:03 PM
Daringer
Darin Gardner
1997 D90 SW
I just installed mine in the Diagonal method. Not pleased with the results. Listing(high) on passenger rear side. Going to change them to "sided" Wish I had just order all A's or B's.
Old February 13th, 2012, 12:07 PM
Bingo.
Old February 15th, 2012, 07:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
To make this thread a bit more useful, I'll throw in my numbers.
Height of the vehicle with stock springs, 265/75R16 BFG A/T with around 28 PSI
at the bottom lip of fender flares:
FRONT - left side (driver side) 87.0 cm
right side 86.5 cm
So far so good, the driver side is a little higher.
REAR - left side (driver side) 88.0 cm
rear side 88.5 cm
Not so good in the rear, shouldn't it be the contrary ?
After taking out the rear springs, I measured them and got
following dimensions:
left 39.2 cm right 38.2
So the left spring (driver side) is taller.
New OME 764 springs have following sizes: 41.7 and 42.6 cm
So no doubt about putting the taller OME on the driver side.
To be continued...
- Charles Eames
Old February 22nd, 2012, 09:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
getting somewhere
before and after, rear left corner.
ID:	48117   Click image for larger version
- Charles Eames
Old February 28th, 2012, 03:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Job is finish, I got + 4 cm on each corner.
Vehicle feel and look much better.
Money well spent.
- Charles Eames
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
OME springs! TwisteD90 Wanted 6 July 15th, 2004 10:20 AM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
