Another electrical issue - Defender Source
Old March 10th, 2016, 03:17 PM
atpick's Avatar
atpick
Andy
1990 110
Trucks been running great. Today during lunch I changed out a headlight and taillight that had burned out. On the way home my instrument gauges died. The gauges and blinkers (which are connected through the same fuse) will only work with the headlight switch on and the brake pedal depressed. I'm thinking a short or grounding issue. I tried removing the taillight that I replaced. That didn't work. Checked the fuse, that didn't work. The voltage measured ok across the fuse. Thoughts?
Old March 10th, 2016, 03:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Make sure the instruments have a good ground, but do not run a separate wire from the battery.
RDavisinVA
Old March 10th, 2016, 03:34 PM
atpick's Avatar
atpick
Andy
1990 110
Yeah, will have a look in the morning once it's light again. I did have a look in the engine compartment and noticed what appears to a grounding strap hooked only to the chassis and to nothing else. Looks to be broken. I am assuming that might be it.
electrical
HELP!! Weird electrical issue phoenix37 Defender Technical Discussions 18 March 20th, 2010 02:36 PM
electrical issue phunter Defender Technical Discussions 8 November 1st, 2008 08:52 PM
110 electrical issue bcourtney Defender Technical Discussions 4 August 6th, 2008 06:40 AM
Electrical issue-dead batt overnight ScottYates Defender Technical Discussions 1 May 6th, 2007 11:21 AM
Need help diagnosing electrical issue cgalpin Defender Technical Discussions 22 January 25th, 2007 08:53 PM
