Another clutch question - Defender Source
Old January 28th, 2012, 03:11 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
so I'm going down the road now that I have my new half shaft in and all is dandy, I get to a stop light and the clutch goes to the floor and engages only at the very end. The problem, I assume, is low fluid or air in the lines? The thing that puzzles me is if you double clutch, it barely engages out of gear but from neutral it works properly. Also I checked the fluid level and it is full. Can I temporarily fix this by bleeding the line? There was a slight drip a couple of times before but has since stopped. Can it still be driven until I replace the master and slave? Thanks for any help
Jason
Old January 28th, 2012, 03:54 PM
Try bleeding and see if that solves the problem.
Old February 7th, 2012, 02:50 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Here we are again, I replaced the slave and master cylinders and bled the line. I put everything back together and fire it up. I depress the clutch but it still wont let me put it into gear so I adjust the pedal on the master cylinder rod all the way at the end. Now it will go into gear but I still am having problems shifting(hard to get out of and into gear at times) and it is slips when I accelerate hard. Any thoughts?
Old February 7th, 2012, 02:54 PM
Do you have proper free play in the pedal?
Old February 7th, 2012, 03:16 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I went from all the way tight on the adjustment rod, where the pedal was set before I did the work to all the way out to the end in 1/8" increments and it would not engage the clutch at all until it was all the way out to the end. I am not missing something am I, there is no other adjustment besides the pedal stop right?
Old February 7th, 2012, 03:43 PM
The pedal has to have some free play in it or it does weird stuff.
Old February 7th, 2012, 03:48 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I had it adjusted so there was play but it was refusing too engage the clutch. Do you need to re bleed after making adjustments to the pedal to relieve any vacuum or does that work itself out?
Old February 7th, 2012, 04:32 PM
Bleed again....
Of course something could be wrong with the clutch end of things.
Old February 7th, 2012, 04:33 PM
Originally Posted by jayz View Post
...there is no other adjustment besides the pedal stop right?
There are two pedal stops that should be adjusted, one for up and one for down.
Old February 7th, 2012, 05:41 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Would the adjustment being off account for the not shifting and the slipping? It seems like it should be one or the other, not both.
clutch
Another clutch question Gunmaker Defender Technical Discussions 3 February 10th, 2011 08:35 AM
Clutch Pressure Plate Question bstraw Series Technical Discussions 4 November 30th, 2010 02:44 PM
Yes, It's another overheating/Fan clutch question bd90 Defender Technical Discussions 11 September 5th, 2009 09:45 PM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
