Another clutch question - Defender Source
Old February 8th, 2011, 08:52 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Last year I put in a new Master Clutch because the original one was leaking on my foot. Everything was fine until four weeks ago when all of a sudden my clutch was gone. I had no fluid. I managed to get her home and filled the Master and bleed the clutch and things were okay for about two weeks but slowly the clutch was getting worse yet I still had fluid.
I replaced the Slave on Saturday. I had a great clutch again!!!!! Worked like it should. By this morning you could push the pedal half way down before it disengaged and she started moving up as soon as you raised the clutch off the floor. Just bleed the clutch again and it is better but I have a problem somewhere. I can't for the life of me find a leak.
Any ideas????
Michael
My Rover doesn’t leak oil, she is marking her territory.
Old February 9th, 2011, 06:09 PM
NC Rover
Nick
1971 Series IIa Hybrid
Any ideas????
Michael
Well its got to be going somewhere. And there definitlely is not a slow leak coming down the clutch pedal to the floorboard and you don't see a leak from the line that connects the master to the slave....that is weird. I can't think of any other places it can go?
Old February 10th, 2011, 08:17 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
I am wondering if I have a slow leak some place in the line that is somehow letting air in and dripping on the converter and burning off. which is why I don't see fluid anwhere. Pedal worked great yesterday after being bleed Tuesday. We'll see today.
Old February 10th, 2011, 08:35 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The seal could have failed and you are simply not getting compression, just moving fluid from one side of the plunger to the other. I had a new MC completely fail in 2 months or so. New one seems to be holding up fine.
clutch
Clutch Pressure Plate Question bstraw Series Technical Discussions 4 November 30th, 2010 02:44 PM
Yes, It's another overheating/Fan clutch question bd90 Defender Technical Discussions 11 September 5th, 2009 09:45 PM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
