Another brand of wheel carrier - Defender Source
Old August 20th, 2014, 09:54 AM
Has anyone seen in the metal or used one of these wheel carriers?
http://www.safari-equip.co.uk/shop/i...l-carrier.html
Old August 20th, 2014, 10:52 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Why has no one thought of that before? Seems like a logical approach, carry the weight...
Old August 20th, 2014, 11:10 AM
I wonder if it depends on the door to bear part of the load. The hinge looks sturdy enough, but the bracket on the cross member looks pretty small to me.
I could be wrong, of course...
Old August 20th, 2014, 11:41 AM
RBBailey
RBBailey
1965 IIa
Am I seeing that it opens with the swing door? No two step process?
------ Follow up post added August 20th, 2014 08:42 AM ------
At first I thought that as well, but I think the bracket is that whole area where the step is.
Old August 20th, 2014, 11:45 AM
I've send them an email looking for more information, including a photo of the chassis mount without a bumperette. Install instructions would help to. There is clearly something going to the door.
I love Clay's mount, but since I have a pintle attached to the crossmember, that would take some modifications before it would work.
Old August 20th, 2014, 11:51 AM
This one is just like the standard mantec, LR and Britpart swing away for station wagons. I don't see a difference. they all mount to the door with a strut. Primary load is by the brackets on the pivot ends bolted through the rear crossmember and capping. the door part only supports a marginal amount of weight, not load bearing. the connecting piece is a plastic strut so the door is stabilized and opens with the door. no two part opening.
the only thing unique here is ability to use it on a tailgate.
Mark Kellgren
KM4BOR
Old August 20th, 2014, 12:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We've carried the Kaymar stuff for a bit and they have basically a more stout two step version that lets you use a tailgate instead of a half door (side swing "tailgate")
Old August 20th, 2014, 12:19 PM
RBBailey
RBBailey
1965 IIa
I may be going through Gig Harbor some time in the next few weeks. May need to make a stop.
Old August 20th, 2014, 12:25 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Please do, would love to see your new truck…
Old August 20th, 2014, 12:32 PM
leeds
Brendan
1996/110 TDi
This Safari Equip wheel carrier is nothing like the Britpart or Mantec wheel carrier.
It is a single pivot wheel carrier which we have fitted to our black 110. It does not require any drilling of the bodywork, however it does require some holes in the rear cross member to take some anti crush cans as the rear cross member is sandwiched between the main mounting pivot and the backing plate.
The door mounting plate just bolts onto the normal holes in the rear door. The connection to the main arm is a sliding mechanism.
The wheel carrier is a one stage operation and all you have to do is open the rear door and the wheel carrier opens with the door.
It will only work with tailgates if they are side mounted half doors. Pre and post 2002 versions are available.
This wheel carrier is not very tolerant of Defender build tolerances. It is made from mild steel and Safari Equip have had issues with their powder coaters. The powder coating firm has changed ownership so hopefully the issues on the coating will be rectified.
If you are going to consider wheel carriers in my opinion the Nakatanenga one is currently the best one available in the UK available here We have one fitted to one of our Defenders.
The Nakatanenga one is powder coated stainless steel so no rust issue here.
A straight forward fit. Two holes in the rear cross member need enlarging from 8mm to take 10mm bolts.
It is a simple bolt on job for the door. The connection from the door is via two stainless ball and socket jobs which takes care of Land Rover build tolerances.
There is tailgate/pickup version in the pipeline.
Brendan
Old August 20th, 2014, 12:58 PM
Would this work when a pintle is fitted and the spare is a 255/85-16 ie 33 inches?
Very very expensive.
SEL 00 - Single Pivot Wheel Carrier, Powder Coated £345.00 + Vat
SEL 00G - Single Pivot Wheel Carrier, Galvanised & Powder Coated £420.00 + Vat
Obviously we don't pay vat.
Old August 20th, 2014, 02:41 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Anything IMO would be an improvement over the OEM soft top carrier. I like this idea. Would be nice if they could incorporate a vertical 3rd brake light arm that goes over the tire too.
I may be wrong, but this one actually looks like the spare is centered on the back of the truck too, which looks better (again, IMO)
Old August 20th, 2014, 02:51 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
How would this work on an NAS rear cross member with the step in place? I like this one a lot.
Old August 20th, 2014, 03:16 PM
leeds
Brendan
1996/110 TDi
For shipping a single carrier to the USA you would be looking at about £80-90
So standard Safari Equip would cost about £430 or about 735 USD delivered
Stainless Nakatanenga wheel carrier delivered to USA would be about 960 USD
Kaymar mild steel one is 968 USD plus possible shipping costs within the USA
These are all single pivot wheel carriers and vastly superior to Britpart or Mantec offerings.
Brendan
Old August 20th, 2014, 03:33 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Not quite.
We retail either Kaymar version at $849.99…
+ USA Shipping from our WA warehouse.
Old August 20th, 2014, 03:44 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
To me, the Allisport solution seemed the best, but I'm guessing this one would be spendy.
Name:	Allisport Spare Tire Mount-1.jpg
ID:	101302   Click image for larger version
Name:	Allisport Spare Tire Mount-2.jpg
Old August 20th, 2014, 04:03 PM
leeds
Brendan
1996/110 TDi
Not quite.
I got my price from Outback Proven website which I got from the Kaymar website. Remember I am on the other side of the pond!
The Alisport wheel carrier was designed by Matthew and know as the Sonic wheel carrier. Last price I heard about the Alisport one was £1,080 inc UK VAT.
Brendan
Old August 20th, 2014, 04:08 PM
Jackie Treehorn
A
1985 (legitimately)
Brendan
Regardless of who designed the Alisport, it looks "smart as a carrot" as I've heard you Brits say!!!
Welcome to DefenderSource by the way, Brendan.
Old August 20th, 2014, 06:09 PM
Mantec or Rockware
Old August 20th, 2014, 07:00 PM
It looks to me like you would have to modify the bumper to fit one of those carriers. The best bet would probably have someone weld it together so the NAS bumper and tire carrier are one piece. I'm not a fabricator though...
carrier, wheel
Another Another 1/10 Scale RC Truck Build - 110! Wolf Fabrication Smaller Projects 11 February 27th, 2014 10:11 AM
Have you ever watched a movie, exit than buy another ticket for another movie? Neil McCauley Misc. Chit-Chat 2 January 31st, 2013 07:23 AM
Yet another tire carrier question kinetic Defender Technical Discussions 9 October 11th, 2011 06:20 PM
Brand New Set of 5 Locking Wheel Nuts kpracer For Sale - Parts 2 December 23rd, 2004 07:29 AM
Brand New Locking Wheel Nuts kpracer For Sale - Parts 2 July 26th, 2004 12:53 PM
