AN fittings @#$%$#@!! - Defender Source
Old July 4th, 2008, 11:30 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
So the AN fittings available in the US appear to be all even numbers.(-2, -4, -6, etc) The AN numbrer corresponds to the numerator of the hose or pipe size; ie -4 means it fits a 4/16 or 1/4 pipe or hose. The rover hoses and pipes are 5/16 by my measurements.... Of course they are!!! It would be too f--king easy to make them compatable! I'm sure this 1/16th difference is crucial to the off road performance of the legendary Land Rover. Anyway, does anyone know if AN -4 or -6 will work with Rover hose/pipe sizes or should I start shopping in the UK? I'm going to post on ORRP and see if I get any feedback.
Thanks and Happy Fourth!!!
...you'll feel better in a couple of days.
Old July 5th, 2008, 12:54 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It depends. What type of hose connections are you working with? If its a low pressure fitting and your just using a press-on flange fitting then close counts. If you are using some exotic high pressure fitting like gates or some other press fit, then I am pretty sure you have to be right on.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 5th, 2008, 02:43 AM
madcowdungbeetle
Carter
You can use a 5/16" to -6 JIC adapter fitting.
Or a -5 AN compression fitting, and adapt it to a -6 AN
Summit Racing is your friend with this.
Old July 5th, 2008, 06:01 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Also pegasus racing has a ton of AN, metric. BSP, etc fittings and adapters.
Old July 5th, 2008, 07:26 AM
Technically speaking, they're not 5/16, they're 8mm. Of course you're quite literally splitting hairs at that point, but if you have the choice of ordering a 5/16 or a 8mm adapter, may as well go with the 8mm.
Old July 5th, 2008, 03:29 PM
rgrrvr's Avatar
rgrrvr
1995 D90
Great feedback thanks fellas!
200 TDI Oil Cooler Line Fittings 49COE Defender Technical Discussions 1 October 13th, 2009 08:21 PM
Roll cage fittings Hoosier Defender Technical Discussions 2 February 18th, 2008 09:17 PM
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
Zerk Fittings on Drive Shafts ronward Defender Technical Discussions 15 January 23rd, 2005 11:27 AM
Lube Fittings Dfndr90 Defender Technical Discussions 4 October 14th, 2004 08:12 AM
