Amount of brake fluid required for renewal - Defender Source
Old September 19th, 2008, 05:55 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Is 500 ml enough for the all system ?
Thanks in advance.
- Charles Eames
Old September 22nd, 2008, 09:58 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bump.
- Charles Eames
Old September 22nd, 2008, 11:55 PM
Yes. It obviously depends on how much you bleed, but one big can 500ml should be more than enough. I recommend castrol GTLMA.
Old September 23rd, 2008, 08:37 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My choices here are limited, i'm using Repsol dot4.
- Charles Eames
Old September 23rd, 2008, 12:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Just did it, it's around 750 ml. To be on the safe side, have a quart or a liter ready.
- Charles Eames
Old September 23rd, 2008, 05:35 PM
Well, I hope I did not leave you needing to make a seperate trip to the store.
Ron
Old September 23rd, 2008, 06:24 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Ron
I had enough to drive to the shop and get some more .
- Charles Eames
brake, mount
Brake Fluid Resv. Switch mpsteil Defender Technical Discussions 6 October 29th, 2009 09:51 PM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
Brake fluid Defender13 Defender Technical Discussions 2 August 27th, 2007 09:33 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
