Am I missing something here? - Defender Source
Old July 19th, 2014, 06:47 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
See photo. I never noticed this. What's missing? Thanks in advance!
Old July 19th, 2014, 07:30 PM
Its the temperature sensor for the a/c system. Do you have a/c?
Old July 19th, 2014, 07:32 PM
the rover shop
shayne young
If I recall that was an overheat sensor for the air conditioning... If temperature got too high it would interrupt the a/c compressor power.. It was a plastic connector and I wanna say they were 2 green..??.. Wires..?
Old July 21st, 2014, 03:21 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok thanks! No air conditioner in my Defender, so I'll just ignore it. Thanks team!
Old September 1st, 2014, 04:39 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi again! My mechanic buddy is insisting that something is missing here. Can I bother a few people to check under their hoods to confirm that they have the same "missing" piece? Thanks everyone!
Old September 1st, 2014, 04:42 PM
87 D110 (Ruby)
you are missing an air conditioner...that is why the plug doesn't plug into anything
Old September 1st, 2014, 04:43 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Lol!!! Ok cool. Thanks!!!
Old September 1st, 2014, 04:45 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Is it on a cooling system fitting? I have run into a couple like this that where for a temp sensor. One was on the tstat housing....other than that I'm going with the a/c switch as mentioned....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old September 1st, 2014, 04:47 PM
the rover shop
shayne young
If he REALLY has to plug something into there you can use that as a sensor to switch the thermo fan relay on.. Comes on about 210-220 if I recall
Old September 1st, 2014, 04:50 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I think this is on the tstat housing. I'll have my buddy take a pic from further out. Thanks!
Old September 1st, 2014, 04:56 PM
the rover shop
shayne young
It's after the thermostat in the housing.. So it only measures temps after the thermostat has opened.. If the engine is still too hot on the output side of the engine then it means the radiator is not doing a good enough job of getting the coolant cool.. The switch turns the load (a/c compressor) off to allow the engine to get cooler.. It's just a make/break switch.. Not really a sensor persay.. But more a temp switch..
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That sensor is designed to shut down your A/C compressor in case your coolant temp is too high, but as said before you can use the port for other temperature monitoring purposes.
Cheers
- Charles Eames
Old September 1st, 2014, 05:03 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks guys. This forum rocks. I really missed you peeps. I'm officially back. The D90 is going to be back on the road (and OFF) soon. So psyched.
what's missing here? wilyliang Defender Technical Discussions 8 January 10th, 2016 02:09 PM
3.5L V8 Rover Engine - am I missing a part here? BEIS Defender Technical Discussions 24 May 26th, 2013 10:16 PM
Here is something Twisted CDN d90 Misc. Chit-Chat 8 March 29th, 2013 10:59 AM
Am I missing something!? sirjond Misc. Chit-Chat 5 October 12th, 2009 04:17 PM
Not a Defender but am I missing something here??? SOUTHPAW26 The Flea Market 13 April 15th, 2009 10:25 PM
