Am I missing something - Defender Source
Old August 5th, 2015, 08:06 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
In the attached picture, is there supposed to be a black rubber piece/shroud the covers up the (vertical) white pieces of aluminum running from the floor boards to the bottom of the dash? The driver side looks the same.
There are probably proper names to describe everything I just mentioned, but my Defender vocabulary still needs work.
Old August 5th, 2015, 08:21 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Yes there is supposed to be the same type of black rubber matting that covers that section of the bulkhead/firewall that surrounds the fuse box as you have on the transmission tunnel.
I also have a 1994 and the passenger side is original and started to crack/crumble. My guess is a previous owner experienced that and removed it entirely.
I just started looking for replacements and there are no simple answers. Does not look like anyone has an original/new version of this piece, none that I can find at least. Does also not look to be much in aftermarket options either.
It does serve a purpose to reduce noise and heat.
Old August 5th, 2015, 11:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Genuine is available. It just now has an extra hole for a hood pull.
Old August 6th, 2015, 09:07 AM
ionfender's Avatar
ionfender
IO
Where can it be purchased? Any idea what the part is called?
Old August 6th, 2015, 09:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
Rovers North
Old August 6th, 2015, 09:21 AM
The Dro
Dro
1988 Ninety
It's pricey
Rovers North - Center bulkhead trim panel
Old August 6th, 2015, 09:42 AM
ionfender's Avatar
ionfender
IO
Originally Posted by The Dro View Post
Wow, no joke it's pricey! After seeing that this has been converted to a nice to have item, not a must have. I also need a rubber cover for the trans tunnel so maybe I'll start by throwing this out as a WTB thread. Probably a long shot but I'll see if anybody has some acceptable used ones.
Old August 6th, 2015, 09:55 AM
It must be possible to track down a similar or better material available in the USA to do the same job......at less expense...
Old August 6th, 2015, 10:40 AM
bjf's Avatar
bjf
barry f
94 ST #395
Get in line. I've had a want ad forever on this.
It is expensive but unless you switch it al to the weight off road version it is your best option for stock.
Old August 6th, 2015, 10:53 AM
ionfender's Avatar
ionfender
IO
Get in line. I've had a want ad forever on this. It is expensive but unless you switch it al to the weight off road version it is your best option for stock.
What's the story on the off road version? Is it something different all together...more expensive?
------ Follow up post added August 6th, 2015 09:54 AM ------
I get the feeling that Line-X is the less expensive USA version...
Old August 6th, 2015, 09:09 PM
wmatos1001's Avatar
wmatos1001
William
Thank you both, I have searched all over RN and for some reason never came across this. Pricey I agree but I need it badly. The rest of my interior has been largely redone, including seats and this eye sore I have for a bulkhead cover has gone on long enough. Solved!
Replace Broken Bolts on LT230 Rear drive Flange-I must be missing something. 95beluga Defender Technical Discussions 4 March 8th, 2015 04:25 PM
Am I missing something here? EnduroPro Defender Technical Discussions 12 September 1st, 2014 05:03 PM
Am I missing something!? sirjond Misc. Chit-Chat 5 October 12th, 2009 04:17 PM
Not a Defender but am I missing something here??? SOUTHPAW26 The Flea Market 13 April 15th, 2009 10:25 PM
What am I missing with this deal? Don't have one yet Misc. Chit-Chat 3 November 28th, 2003 10:28 AM
