Aluminum wheel centercap question - Defender Source
Old March 4th, 2015, 01:54 PM
89Defender90
none
none
Registered User
I have the 16" aluminum Defender wheels and the dust/hub cap sticks through the center section of the wheel and doesn't allow for the use of centercaps. Is there a lower profile dust cap that can be used that will allow me to put centercaps on the wheels? or am I just missing something?
Old March 4th, 2015, 02:58 PM
Alloys weren't designed for the early Rover axles.
Old March 4th, 2015, 03:08 PM
Also.... have a close look at the drive flange.... the bolt heads will interfere with the wheel and prevent it from fully seating on the hub. Many people don't notice and it is not safe.
Old March 4th, 2015, 03:14 PM
89Defender90
none
none
Registered User
I was told that the wheels came on the truck. 1989 ROW 90
Old March 4th, 2015, 03:17 PM
Defenders did not come with any alloy wheels prior to the 300TDI era, AFAIK. No standard LR alloy wheels will fit the early axles without spacers or machining/grinding out the inside of the wheels.
How about a picture of the axle and rims to see what you have....
Old March 4th, 2015, 03:24 PM
89Defender90
none
none
Registered User
My understanding is that they are the standard non-salsbury axles.
ID:	115250   Click image for larger version
Old March 4th, 2015, 03:38 PM
Yep, unless someone has removed material inside of those wheels, they are hitting the drive flange bolt heads. Look inside the wheel for damage.
Old March 4th, 2015, 03:53 PM
89Defender90
none
none
Registered User
Looks like two have been grinded out and two haven't. So the next question is...What's the smallest spacer I can use that still allows the wheels to be hubcentric?
ID:	115260   Click image for larger version
Old March 4th, 2015, 03:54 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
You can run them no problem with a set of 30mm wheel spacers.
Legend in My Own Mind.
Old March 4th, 2015, 03:56 PM
89Defender90
none
none
Registered User
I don't want to bolt on a spacer, I'd like to just put a smaller 1/8"-1/4" if it will work. My tires are already sitting nicely, I think the 30mm would set them out too far for my personal preference.
Old March 4th, 2015, 03:58 PM
There used to be guys selling 1/4" spacers for this purpose, but I can't find them anymore.
Old March 4th, 2015, 04:04 PM
89Defender90
none
none
Registered User
found some 10mm on ebay.uk
Old March 4th, 2015, 04:14 PM
10 mm seems a bit much. I'd be worried about having enough stud thread left. Got a link?
Old March 4th, 2015, 04:16 PM
89Defender90
none
none
Registered User
meant 6mm, little less than 1/4"
Old March 4th, 2015, 04:28 PM
89Defender90
none
none
Registered User
6mm aluminium wheel spacers 5x165 land rover set of 4 | eBay
Old March 11th, 2015, 06:14 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
Have you tried these yet? I'm interested to hear how you get on.
Old March 11th, 2015, 08:18 PM
89Defender90
none
none
Registered User
Ordered them, but 2 weeks shipping from UK. hopefully they'll come in next week. After looking at the wheels, even with the 6mm spacers, I'm not sure if the dust cap will allow use of the wheel center cap
If they don't, I'm planning on just painting the dust cap silver....
Old March 19th, 2015, 09:28 PM
89Defender90
none
none
Registered User
Put the 1/4" spacers on. They do keep the bolt heads from hitting the back of the wheels, but unfortunately they don't push the wheel out far enough to fit centercaps.
Here are some pics. One before with low profile dust cap, one with spacer installed and low profile dust cap, and one with spacer installed and regular dust cap.
I'm going to just clean the cap up and spray them silver.
ID:	116474   Click image for larger version
aluminum, wheel
Aluminum wheel spacers KSARover110 Wanted 0 January 21st, 2013 07:58 AM
Aluminum wheel spacers "used" jonathon For Sale - Parts 10 December 19th, 2012 08:13 PM
One clean Boost alloy rim with centercap 2yellowlabs For Sale - Parts 4 March 17th, 2011 11:42 AM
Wheel Adapter - NOT steering wheel nikojo Defender Technical Discussions 0 June 9th, 2008 12:49 AM
Safarigard 1" aluminum wheel spacers dannykkim Defender Technical Discussions 1 March 7th, 2005 04:29 PM
