Aluminum hinges installed - Defender Source
Old November 10th, 2013, 10:13 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I've done searches for "aluminum hinge" and all the results seem to divert off to "get stainless steel" or "Britpart is garbage". So I decided to "blaze a trail" and order a set from Paddocks. I was replacing my doors at the same time, so it seemed to be a good time to do so.
The new doors are Britpart also, which I regret buying (another topic....).
The hinges were supposed to come with all mounting hardware. It came with all the nuts & bolts, including the trapped nuts attached to the body. Unfortunately they did not come with new mirror attaching screws - the old ones might work, but they will not go into the recessed holes. I had to buy four Allen head bolts.
As far as fitting the hinges, it was uneventful, i.e. it went as planned. No alignment issues, not poor fitting issues, no failures, etc... I re-used the plastic spacers on both the body and the door.
The next issue arose was because the hinges are larger than factory hinges. As other posts about aftermarket hinges and soft top doors, the hinges hit the door capping (but only one side due to crappy doors). I ended up trimming off a bit of the newly-painted capping.
I plan on leaving them unpainted - they're not shiny. Attached are a couple of photos, including one comparing the old and new size-wise.
ID:	83933   Click image for larger version
aluminum
Aluminum Hinges kevkon Defender Technical Discussions 28 July 28th, 2011 08:58 AM
Motosource aluminum hinges and SS hardware D90user For Sale - Parts 4 April 4th, 2008 08:14 PM
Aluminum HT w/lift gate & internal SD roll cage jabber For Sale - Parts 21 December 21st, 2005 12:36 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
motosource hinges tonymotosource Misc. Chit-Chat 0 December 9th, 2003 09:50 AM
