Aluminum Fasteners. - Defender Source
Old March 11th, 2010, 09:40 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Aluminum Fasteners.
Any reason why chequerplate has steel fasteners instead of aluminum? I'd have thought that a non-pure (stronger) alloy fastener would be more than strong enough (especially given that I'll likely be bonding them in place anyway to fill the gaps) given that wing-tops and quarter panels really don't get the kind of abuse that would require strength.
Old March 11th, 2010, 10:07 AM
mine are held down by alloy pop rivets. skip the adhesive, not required, or wise. you may need or want to remove them at some point.
Old March 11th, 2010, 10:17 AM
ajh
Andrew J. Hutton
Ok, need to put something between though, there is too much flex-gap now, I wanted to use silicone sheeting but that stuff is way too pricy. Guess just running a neoprene seal around the edge would solve crap getting between the two surfaces. I also have a rubberized isolation product I'll coat the bottom of the plate with.
Old March 11th, 2010, 01:33 PM
yeah, crap will get in there. not a concern for me. maybe a bead of household latex caulk will seal it up fairly well and be easily removeable should you want to do so. though to really get a perfect seal you'll need alot more rivets, no matter what you use. are you worried about damage to the paint?
Old March 11th, 2010, 01:49 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I used sided 2 sided tape on mine. the stuff body shops use to attach name plates. dont use silicon you will likley pull the paint off if you ever need to remove them.
Old March 11th, 2010, 02:18 PM
ajh
Andrew J. Hutton
Ah, yeah ideally some silicone tape would probably work best, stuck to the plate and not the paint. I am likely going to also put a paint film on the wings/bonnet edges to protect the paint, mostly I just don't like a gap between the two surfaces. Yeah, I am being a bit anal about things but we all have our quirks
Somehow Paddocks managed to put the arial hole on the wrong wing too, so thinking I will cut one where the am/fm arial goes and sandwich a plate under the wing on the other side and mount the CB/FM 2-way arial on that side.
Thanks for the ideas.
aluminum
Aluminum top and parts redrover For Sale - Parts 12 March 28th, 2006 08:45 AM
FREE D90 Aluminum Roof Panel Roadsiderob For Sale - Parts 13 February 15th, 2006 11:38 PM
Aluminum HT w/lift gate & internal SD roll cage jabber For Sale - Parts 21 December 21st, 2005 12:36 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
stripping aluminum mattdh Defender Technical Discussions 2 November 10th, 2003 03:19 PM
