Aluminum corrosion, WTF!!?? - Defender Source
Old September 4th, 2011, 08:23 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
So I started some prelim. dismantling of my truck today to just get some bad bolts out of there and replaced with stainless and to get a good look at some problem areas. I was ripping out the ratty old carpet in the back and under the middle row of seats and this is what I uncovered. Im guessing it's electrolysis? It seems to be only where the aluminum is touching steel.(there are two bolts in there) What can I do to contain it? I am going to replace the panel that is really bad but it is happening in some other corners and I want to stop it before it gets bad. Any insight will be greatly appreciated
Old September 4th, 2011, 09:28 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Leave the carpet off? Just joking. Good start with replacing with stainless. Some have also placed either rubber or nylon washers between the stainless and aluminum.
Old September 4th, 2011, 09:59 PM
Make sure you don't let stainless touch aluminum directly
Old September 5th, 2011, 07:52 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Amorcoat or galvanized fasteners would be better than stainless. There's too much difference between the anodic index between the aluminum in the panels and stainless. Not quite as much between Al and HDG, and even less between Al and Armorcoat fasteners because their top coat is aluminum.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 5th, 2011, 09:43 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I think there should be a rule that Land Rovers shouldn't be allowed above the Mason-Dixon line. They last so much better in the south
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old September 5th, 2011, 10:15 AM
Grover's Avatar
Grover
Thumbs up
Another tip is to wrap electrical tape around the treads to isolate the Al and SS. I did this when I replaced with SS.
Cheers...
Old September 5th, 2011, 10:42 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
This is a common problem with boats and they have systems to help minimize it. Anytime you have metal to dis-similar metal contact you will have the potential to have the problem we have with the Rovers. Added to the problem is when you have the metal in a good ground contact. You may find the better the ground contact the more problem you will have. In other words I had a big problem at the rear floor where it connected to the metal support that was directly connected to the frame. Isolation is the key to help minimize the effects of galvanic action. The more paint on the parts and or rubber/plastic isolators will help. Stainless is great but as mentioned above may help facilitate the problem as compared to some other metals. Be careful as stainless is not all made equal as it comes in all types of grades.
Land Rover 110
Old September 5th, 2011, 11:16 AM
discotdi
Todd Miller
Land Rover
I have the same problem. Not too bad now, but all the area around the second row bolts as well as some spots on the cargo floor have the corrosion. So how do you treat and stop the corrosion?
Old September 5th, 2011, 11:38 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Sounds to me like all you need to do to stop it is isolate the steel to AL connection and paint the crap out of it. Thanks to everyone
Old September 5th, 2011, 12:28 PM
discotdi
Todd Miller
Land Rover
So just grind away the corrosion to bare metal, isolate metals, and paint?
Old September 5th, 2011, 12:44 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Pretty much. I use Nylon washers on both sides of any Al / Fe interface. Religiously. I even found some washers that have a little rib that drops into the hole to protect the panel from the threads on the bolt.
Old September 5th, 2011, 12:46 PM
Neill:
Where is your preferred source for the nylon washers? Just curious...I haven't typically used these (read: laziness), but probably will going forward or maybe even retroactively on some I've done so far.
Old September 5th, 2011, 01:10 PM
navydevildoc
Neill Thornton
We are very fortunate to have a place called Marshall's Industrial Hardware here in San Diego that is total man project nirvana. Rows and rows and rows of specialized bolts, washers, fittings, you name it. That's where I get everything.
But Grattan Fasteners made the box of nylon washers I have.
Old September 5th, 2011, 03:27 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I just went to my local hardware store and got some. The ones I got are made by Servalite but they come in individual packages of 1. Going to look them up and see if you can get them by the box. I am assuming the nylon is better than rubber.
Old September 5th, 2011, 03:54 PM
d110pickup
Mike Pado
'97 D90 ST #1153
A simple and easy solution is to do what the aircraft industry calls "wet Install" all fasteners that pass thru dis-similar metals. We would also use a sealant between dis-similar metals. The nylon washers referenced above would work as well. An unbroken layer of paint on each of the surfaces will also help.
BTW I'm a Manufacturing Engineer at Lockheed and have a bit of experience with this topic.
aluminum
Galvanizing question Mark McDonough Defender Technical Discussions 25 November 4th, 2009 08:41 PM
Aluminum HT w/lift gate & internal SD roll cage jabber For Sale - Parts 21 December 21st, 2005 12:36 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
Aluminum Mud/Sand Ladders C-Delta For Sale - Parts 5 July 12th, 2004 11:02 PM
stripping aluminum mattdh Defender Technical Discussions 2 November 10th, 2003 03:19 PM
