Alternator Wiring Question - Defender Source
Old September 21st, 2011, 06:46 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ok, dumb question time, but trying to figure out why my alternator is giving 18v now, and replacing the regulator didn't help.
Wiring. Big brown wire is the output.
small brown/yellow goes to the charging light circuit.
white/grey for the alternator output.
Diagram calls for a ground cable, but mine only has the above 3 wires on it. Is there also supposed to be a separate ground on it?
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 21st, 2011, 10:05 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
We are talking about your 94 nas? Stock alt?
Your wiring sounds right. Does the charge light come on in the dash when you turn the key on? ie the bulb is good?
Ground may be referring to the resistor on the back?
Old September 22nd, 2011, 09:22 AM
Hans's Avatar
Hans
Hans Haase
Bulb is very very dim, when it's on at all. Swapped in a known good bulb too, same result.
Brown/Yellow is also the voltage sense circuit, correct? What voltage should I be seeing there? Only seeing around 9v on that wire, the other two (Output and tach output) are giving me battery voltage.
Probably running the ground circuit through the case, and into the engine block I guess.
-Hans
My oil line fix
Old September 22nd, 2011, 09:45 AM
Maybe our colors are different, but for me the yellow wire from the Defender goes to D+ for ignition, and the Defender grey/Purple with white stripe wire goes to W for tach.
Old September 22nd, 2011, 10:51 AM
Hans's Avatar
Hans
Hans Haase
Yeah, I think they must have change the colors in '95 I've got brown (the main output), brown/yellow (sense/lamp) and white/grey (tach).
-Hans
My oil line fix
Old September 22nd, 2011, 11:03 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Old pick off of my 93
Old September 22nd, 2011, 11:08 AM
Hans's Avatar
Hans
Hans Haase
Interesting, yours does have a ground wire on the case. Tried adding one, no success.
Heading to the alternator shop in a little bit here to get it tested, but I'm suspecting a wiring issue and not an alternator issue. Will dive into that dummy light circuit when I get back.
-Hans
My oil line fix
Old September 22nd, 2011, 12:34 PM
jijalicious
Jiman Khosravan
'94 D90
Sorry side track.. but the brown cable that is attached to the bolt (grounded)... is that the one from the ignition module?
~Jij
Old September 22nd, 2011, 04:47 PM
mattarm's Avatar
mattarm
Matt
1993 D110
If that ? was directed at me, I cant say as my truck is currently in just less than 1,000 pieces.
Old September 24th, 2011, 10:11 AM
James Pierce
James Pierce Jr.
So what's the prognosis?
Old September 24th, 2011, 10:22 AM
Hans's Avatar
Hans
Hans Haase
New regulator is dead in the same way as the old, have another one on the way that should be here tomorrow. No idea the cause yet though, shop still has the alternator.
-Hans
My oil line fix
Old September 24th, 2011, 09:55 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Is your battery holding a charge?
1970 SIIA 88, Sold
Old September 24th, 2011, 10:13 PM
Hans's Avatar
Hans
Hans Haase
Well, the previous battery got fried before I noticed the problem. Replaced it the same time as the regulator, and current battery is doing fine.
-Hans
My oil line fix
Old October 4th, 2011, 03:48 AM
Hans's Avatar
Hans
Hans Haase
Not sure what really happened on this one, but all is well now with ANOTHER replacement regulator.
Wierd that I had both the original go bad, plus the replacement, with the same unusual problem. Had a local alternator shop install it this time and do a run-in to seat the brushes. Seems fine now, voltage is holding right where it should be.
Also found out that a good alternator shop can get the regulator for the Marelli's with no problem at all. IIRC the part number is IX128 or IX127 (Same regulator, one has a longer stud for the tach output). Ran me $50 for the part, install and diagnostic work.
-Hans
My oil line fix
alternator, wiring
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
