Alternator Voltage - Defender Source
Old October 8th, 2016, 06:58 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Alternator Voltage
What voltage is your alternator producing?
My Marelli at idle is producing:
14.7 no load
14.5 lights & fan
The manual states 14.6 min. If it is still
1+ over battery voltage that should be ok? My
Little test gadget tells me my diodes are fine.
I would think the lower acceptable voltage would
be easier on the battery. Battery is putting out 12.4.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 8th, 2016, 07:59 PM
Looks good to me.
Old October 8th, 2016, 08:30 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That is very very good.
RDavisinVA
Old October 8th, 2016, 08:42 PM
Really? I think you might be reading something wrong in the manual.
This is from the genuine manual for the NAS Defender.
Manufacturer .................................................. .................. Magnetti Marelli
Type .................................................. ............................... A127 - 100amp
Polarity .................................................. ........................... Negative ground
Brush length:
New .................................................. ....................... 17 mm 0.67 in
Worn, minimum free protrusion from moulding ....... 5 mm 0.20 in
Brush spring pressure flush with moulding ...................... 1.3 to 2.7N 0.25 to 0.60 lbf
Regulator voltage .................................................. ........... 13.6 to 14.4 volts
Nominal output:
Generator speed .................................................. ... 6000 rev/min
Control at 14 V .................................................. ...... 65 A
and later on
The regulating voltage is set during manufacture to
give the required regulating voltage range of 14.2
0.2 volts, and no adjustment is necessary. The only
maintenance needed is the occasional check on
terminal connections and wiping with a clean dry
cloth.
alternator
Bad Voltage Regulator? New alternator? BEIS Defender Technical Discussions 7 May 3rd, 2013 01:14 PM
Odd Voltage Alternator problem Bill Larson Defender Technical Discussions 11 June 12th, 2012 07:47 PM
alternator circuit voltage drop and ripple voltage values JFD Defender Technical Discussions 2 November 29th, 2010 07:13 AM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 10:24 PM
help - where is my voltage KeithD Defender Technical Discussions 26 November 13th, 2003 03:11 PM
