Alternator recommendation - Defender Source
Old November 8th, 2015, 12:07 PM
usadventureracing's Avatar
usadventureracing
Brett
110
I need a new alternator for my rhd 3.5 v8. Anyone have a recommendation, part number?
1983 ROW D110
1970 Series III (Parting out)
Old November 8th, 2015, 12:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
So I have a Mean Green and it has been awesome and puts out tons of juice (around 200A, I believe). But when you look closely at it, it really appears in all ways to be as delco cs144 alternator which is a super common alternator. Go pull one from a junk yard and for pretty darn cheap you can get new brushes, rectifier, and even a heavy duty diode pack. Here are their part numbers that I used on mine: Brushes BWD #X393. HD Bridge rectifier Transpo #7179 or Wai 5179, Regulator Transpo #D411XHD . (I think there may be two CS144 styles, old and new--you'd have to do a little research but mine is the "new" style and that is the one I ordered brushes for. I don't know the differences, but I think it is just the way the brushes are held in. So make sure you double check my part numbers for your make, which ever you find. Bearings are super cheap too, so replace them as well and you have a new alternator for the most part.
This way you will get a 180-205A alternator what, $25 at a pull/parts place, you will drop maybe $50 on new electrics and bearings (since it is out of the truck anyway, why not...) and have a very powerful alternator for $75. You will have to make a correct bracket and use washers (or mill a spacer) to get it perfectly positioned, but that is a super simple job even with just a drill, 2 pieces of flat steel, a hacksaw and a file (or hopefully "easier tools" but this can be super basic. I'll grab a photo on my current engine which is crank pump/serp belt. If you have V-belt, it will work too as I ran this on my last engine, just different spacers...
One last thing--when I changed my rectifier (part number above) I chose one with a slightly higher charge voltage which pairs well with my AGM Odyssey battery. So you may want a little lower voltage, maybe below 15, for yours--your choice. Just want to be thorough since I started pulling part numbers here...
Let me know if you want to see a pic. I may have one from when it was v-belt too...
Old November 8th, 2015, 01:30 PM
I have an Action Alternator 140amp - great unit
Just call them and they can customize it for you to fit your setup
Home - action alternator and starter
95' D90 - daily driver..
Old November 8th, 2015, 03:01 PM
usadventureracing
Brett
110
Thanks i am going to call the company in utah on Monday. This the sicker on mine looks to be from 2001
1983 ROW D110
Company Recommendation Viton Defender Technical Discussions 9 June 3rd, 2012 12:37 AM
Winch Rope Recommendation (for XD9000i)??? limeport Defender Technical Discussions 9 June 22nd, 2009 05:30 PM
Shock brand recommendation Rubicon21 Defender Technical Discussions 3 September 25th, 2007 05:31 PM
Jack Recommendation TDI Guy Misc. Chit-Chat 16 April 5th, 2006 12:43 PM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
