Alternator noise? - Defender Source
Old June 29th, 2014, 03:34 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Alternator noise?
When running the alternator makes a loud whine/whirring sound. It's a Bosch that's relatively new, but sat for about three years while redoing the rest of the D90. It charges fine and everything, just loud. Has anybody else encountered this?
Old June 29th, 2014, 07:28 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
My bad ones sounded like a grinder or popcorn maker...keep an eye on the tach gauge when it starts to move erratic then it's going bad. I'm on my third alternator and this one's a Boch, so far I've made it a couple years but now I keep one in inventory. Good Luck!
Old June 29th, 2014, 08:07 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Is it from the belt or actual belt making the noise?
Old June 29th, 2014, 11:00 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I'm pretty sure that the noise is coming from the alternator. I guess i could try loosening the tension on the belt and see if that helps. I will keep an eye on the tach. The noise is more annoying then anything, as we all know, it's already a loud vehicle. I'll just tell people that it has twin turbo or something.
Old June 29th, 2014, 11:46 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Take the belt off, spin alternator pulley by hand, if it's loose, noisy or spinning too easily your bearings are shot.
You can swap them.
- Charles Eames
Old June 29th, 2014, 08:56 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks for the replies. Keep them coming.
Old June 29th, 2014, 10:16 PM
Spray some WD40 on the front & rear bearing...if the noise goes away, you've got your culprit.
alternator
Ominous Alternator noise! Eric Siepmann Defender Technical Discussions 14 May 16th, 2005 05:34 PM
Fuel pump noise PT94D90 Defender Technical Discussions 3 March 3rd, 2004 05:48 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
wind noise with fiberglass top GliderKing Defender Technical Discussions 4 October 10th, 2003 04:13 PM
